Old 08-13-2012, 10:08 AM   #1
focusedontheprize
focusedontheprize's Avatar
Coating inside of the cab - what did you use
I realized I have not updated my build thread in a couple months so I will do that this week (currently at work).
Right now, I have the cab and bed mounted on the frame. So I started cleaning out the interior (removing moldings, gauges, fuel tank, etc) and really looked at the floor. The floors are 98% solid (only holes I have really are the transmission cover which i will replace), but I do not want to "finish" the cab. I wanted to keep the rustic look to it, but prevent any further rust.
So here is my dilemma:
I was thinking of coating the whole inside (from below the rear window to up the firewall) with POR15. I think it will hold and preserve the cab much better than anything else and also means I don't have to take it down to bare metal. The issue is the cab is on the frame and the frame is painted. If I use the Metal Prep I have to spray the inside of the cab out which is a pain and I am going to have to bag everything and try to keep the water down.
I am looking to see how you guys finished off your cabs (especially the rat rod guys). I just didn't think epoxy was the best move.
focusedontheprize is offline   Reply With Quote
Old 08-13-2012, 11:48 AM   #2
OrrieG
OrrieG's Avatar
Re: Coating inside of the cab - what did you use
I used the POR-15 but had the cab off so it was no big deal. Where there was no rust I touch sanded and used a brush on rustoleum oil base paint under the dash and on surfaces that will be covered. rest got epoxy primer and base clear coat.
Old 08-13-2012, 11:59 AM   #3
oldcouple
oldcouple's Avatar
Semi gloss Rustoleam, brushed it on, my body shop guy did the floor with lizard skin, not impressed, it chips off. There is a thread in the paint section on making your own.
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 08-13-2012, 06:24 PM   #4
mknittle
mknittle's Avatar
Some guys are using spray on bed liner with good results.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 08-13-2012, 08:41 PM   #5
parkwood
parkwood's Avatar
we used lizard skin and sound deader.. worked great to keep the heat out and make it sound proof..
parkwood is offline   Reply With Quote
Old 08-13-2012, 09:05 PM   #6
Kid
Kid's Avatar
+ 1, I'm happy with the Lizard Skin too, glad I didn't have to buy enough for that sub!
Kid is offline   Reply With Quote
Old 08-13-2012, 09:12 PM   #7
parkwood
parkwood's Avatar
Yes it works great, but almost afraid to say what it cost... took my breath away...
Old 08-14-2012, 07:45 AM   #8
focusedontheprize
Ok cool thanks for the responses.
After some thought yesterday, I am going to just POR15 the firewall, floors and back of the cab. I will just have to bag everything to make sure it is completely dry.
@OrrieG: I was considering doing the bedliner, but figured if I am going through all the work of prepping the cab, I will just do the POR.
@Parkwood and Kid: Thanks for the recommendations on the lizard skin. I will have to try that on another one of the projects. Surely, this isn't the last one. Hahaha
Old 08-15-2012, 10:16 PM   #9
TX58
I did several coats of rattle can bed liner. Used it from behind the gas tank all the way to just below the dash. I'm using a factory style mat so most of it will be covered. I also coated the firewall,underneath the floors, cab with the same spray bed liner. I'm happy with it.
TX58 is offline   Reply With Quote
