08-13-2012, 08:43 PM | #1 |
Slugish
Plug wire routing /pics please
Whats some good ways to route plug wires without spending a fortune on those fancy gizmos that attach to your valve covers & you thread your wires thru. They look great & neat but Idont want to spend 75.00-80.00 on something like that. Also should Ikeep my wires up off the valve covers .
Ideas & pics would be great . |
08-13-2012, 09:09 PM | #2 |
Re: Plug wire routing /pics please
You could use zip ties.
08-13-2012, 09:18 PM | #3 |
lol yeah i've always used zip-ties..
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
08-13-2012, 10:43 PM | #4 |
I have used zip-ties just like that i think i found out about that trick in an old hot rod magazine.
08-14-2012, 09:50 AM | #5 |
zip ties can actually make a good look, i saw it on spike tv's trucks once, just use a big one around all 4/3/2 (however many you have at the same spot) and then use a small one to go inbetween each wire, i did it with my old cavalier and it looked pretty good actually, ill come up with pics sometime soon
08-14-2012, 09:51 AM | #6 |
darn mongoose beat me too it, nevermind
08-14-2012, 12:33 PM | #7 |
Do you have headers or stock manifolds, or Rams horns?
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
08-14-2012, 12:51 PM | #8 | |
I've always found that the factory wire loom setups work fine for me, with or without headers. Depending on what you are working on most all of your factory wire loom holders are reproduced and they are relatively inexpensive. Some route over the covers, some down the sides, some of your older trucks even ran under the manifolds and up the back of the block and bellhousing area and then come up the back of the cylinder heads by the distributor. (one of my personal favorites as they are almost completely out of site) |
08-14-2012, 02:21 PM | #9 |
Thanks for the idea, mongoose and exfordman! I just ran new wires last night and wanted a way to clean it up a little. I'm picking up some zipties on my way home tonight!
1985 C2500 3+3 Sierra Classic 454/TH400 Stock right down to the wheels, it's primary purpose is to haul cows. It's secondary purpose is to provide me with many hours of fun and frustration. |
08-14-2012, 06:17 PM | #10 |
Jegs has them for 14.99 and come in many colors.
http://www.jegs.com/i/JEGS-Performan...rentProductId= |
08-14-2012, 07:40 PM | #11 |
Slugish
Thx All ,
Ive got headers bt the way manimal Ive got these long T BOLTS that you screw into studs to hold valve covers down . Had a blue zip tie that actuall matches my plug wires .tried it looks ok to me Will zip tie 2 plug wires to each of the 4 t bolts ( can get antwhere --made by Spectre) Also with the zip ties you can secure your wires where they are away from your headers& valve covers. Good idea. Is there any better forum than this !! |
08-19-2012, 11:51 AM | #12 |
i had seen a routing method with zips that used one inbetween each wire to separate them. hard to describe, but looked cool!
Found this link to demonstrate what im talking about: http://www.circletrack.com/enginetec.../photo_21.html ** here was a link in our forum that has some nice ideas on routing: http://67-72chevytrucks.com/vboard/s....php?p=3306169 ** |
08-19-2012, 12:07 PM | #13 | |
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
08-19-2012, 12:57 PM | #14 |
Happy to be here
If you want to clean up your motor get rid of the retro 80 T bolts. Heres how I routed mine...
08-19-2012, 04:31 PM | #15 | |
Best factory plugwire setup in my opinion, keeps them out of sight. |
08-20-2012, 01:45 PM | #16 | |
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
08-20-2012, 01:57 PM | #17 |
08-20-2012, 09:14 AM | #18 |
You can route the under the headers using adel clamps if your headers have room or I like Taylor cable looms for above the headers. Check them out here. http://queencityspeed.blogspot.com/2...lug-wires.html
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
08-20-2012, 04:37 PM | #19 |
I used these and came around from behind the heads.You don't see much.I used red wires with a red dist cap.Look's cool Imo.I know you said you didn't wanna spend that much.I got a used set that look's new off ebay for under 20 clams.
" Never look up a dead dogs butt." |
08-20-2012, 04:49 PM | #20 |
Not to be a pest, but i think we need to keep each wire at least .5 inch away from each other. Especially 5 and 7.
Elaborate. |
08-20-2012, 05:18 PM | #21 |
08-20-2012, 06:42 PM | #22 |
