Old 08-13-2012, 11:52 PM   #1
Solo2002
Solo2002's Avatar
Talking Xmember mods
Ok I'm new here and I have a 66 C10 short step side and I wanna go as low as I can with static drop I have seen a hand made drop member from the factory one but not sure on how to do it. Any help on this would b great and I have a pretty good make it work look on things so I'm open to ideas but money is short needs to be cheap
Solo2002 is offline   Reply With Quote
Old 08-14-2012, 12:23 AM   #2
Captainfab
60-66 Nut
Re: Xmember mods
Check out Dino's dually build in the 'Projects and Builds' section. I believe he pancaked the crossmember on that one. I know he did the crossmember on the orange Suburban he used to have. You will have to do a search for that build thread, it was a couple years ago.
Old 08-14-2012, 12:29 AM   #3
Solo2002
Solo2002's Avatar
Re: Xmember mods
Ok thanks
Old 08-14-2012, 12:54 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Xmember mods
I've seen it referred to as "pancaking" the crossmember. Basically you end up sectioning some of the center of the crossmember (so horizontal cuts, across its width). I will say, my truck is static and although somewhat low, even at only a ~4/6 drop my crossmember can get damn close to the ground and be a pain on speed bumps etc.
Good luck, and hope you got time and a good welder!
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-14-2012, 07:20 PM   #5
Solo2002
Solo2002's Avatar
Re: Xmember mods
ok checked out Dino's dually thats what im wanting but i kinda need like a cut here move there weld this kinda post.I really dont wanna mess it up and have to hunt down anotherone
Old 08-14-2012, 11:06 PM   #6
s11sean11
Re: Xmember mods
on my truck I raised the cross member heres pics on how it was done http://67-72chevytrucks.com/vboard/s...d.php?t=478965
s11sean11 is offline   Reply With Quote
Old 08-14-2012, 11:39 PM   #7
Solo2002
Solo2002's Avatar
Re: Xmember mods
Ok that could work just add to the frame then cut out the desired amount and move the crossmember up. But witch would b better this way,the pancake xmember,or the old school Z the frame I have had like 10 reflector collectors but this front suspension here I'm lost I drop it and hello bump stop look at swapping it for a shorter stop and then it's the steering shaft I know spindles are gonna have to go on that's a must
Old 08-15-2012, 12:18 AM   #8
Captainfab
60-66 Nut
Re: Xmember mods
When you raise the crossmember, that raises the engine up as well. Then you can have engine and trans to cab floor issues.
Old 08-15-2012, 12:28 AM   #9
s11sean11
Re: Xmember mods
the way I did it it I had no clearance issues
Old 08-16-2012, 06:48 PM   #10
Solo2002
Solo2002's Avatar
Re: Xmember mods
I might actually have a clerance issue anyway not sure yet but im gonna run a chevy 350 with a muncie 4 speed i dont think there will be a problem with clearance issue but i might any info on that would much appricated thanks for the info guys
