Sloppy Tilt Column Repair
I'm in the middle of tightening the loose bolts in the steering column as detailed by Captkaos in his "Fixing a Sloppy GM Tilt Column" thread. I just got the bolts tightened and will start putting it back together tomorrow.
I found a small ball bearing laying on the seat as I was cleaning up for the day. My first thought was that a ball had fallen out of the upper bearing cage. I checked the cage, and all the balls are still in place. I have no idea where that ball came from. Does anyone have a clue where the mystery ball may have come from? Thanks for any suggestions, Les |
18 Till I Die
Re: Sloppy Tilt Column Repair
Out of the signal switch? a detent ball of some sort...I have a few of these columns apart and the upper bearing race would be my guess, unless the bearing was replaced before and it was left behind?
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
Windy Corner of a Dirty Street
Uh, oh.....I believe that ball bearing goes in the cage that is right above the upper stub (# 46 in picture). The bad news is you have to take it all apart to stuff it back in the cage. The image is a G-van Saginaw column but still pretty much the typical Saginaw column dealeo in all GMs of the era.
![]() Another view….Remember this sight? The bearing cage sits at the base of this stub below the upper housing, which is the biggest PITA of the whole mess to get off. ![]() ![]()
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
[QUOTE=DirtyLarry;5539807]Uh, oh.....I believe that ball bearing goes in the cage that is right above the upper stub (# 46 in picture). The bad news is you have to take it all apart to stuff it back in the cage. The image is a G-van Saginaw column but still pretty much the typical Saginaw column dealeo in all GMs of the era.
Another view….Remember this sight? The bearing cage sits at the base of this stub below the upper housing, which is the biggest PITA of the whole mess to get off. ![]() Are you saying there are 2 bearing assemblies on the upper housing? #46 and #32? |
You were right, there is a second bearing there and it was the one with the missing ball. I was able to snap the ball into place without taking anything else apart.
Thanks for your help, DirtyLarry. |
