08-14-2012, 11:36 PM | #1 |
Any of you guys running a rearsway bar?
who has a rear sway bar on their truck? not talking the guy with the full hotchkis kit. i saw a rear swaybar on summitracing for 130 for my truck. im curious as to how much of a difference it makes in the handling and ride of our trucks.
-Mike- '94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s |
08-15-2012, 02:11 PM | #2 |
Registered Cruiser
Re: Any of you guys running a rearsway bar?
I installed one on a friends truck. I stiffened the ride too much, and he ended up removing it.
I intend to live forever. So far, so good. |
08-15-2012, 03:01 PM | #3 |
I just received mine from LMC, but have't installed it yet. I wouldn't expect it would stiffen the straight line ride much, it's intended only really to come into play when then two rear wheels are trying to be at different heights.
I suppose if you went over a bump with the right wheel it might upset the left more than if you didn't have a sway bar.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
08-15-2012, 03:25 PM | #4 |
I had the one from Classic Perform and loved it, however when I replaced my trailing arms to the square tubing ones they reccomended not to put a sway bar on so I ended up selling here on the board. the truck had almost no body roll
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
08-15-2012, 05:58 PM | #5 |
Love That '69
I installed a rear swaybar on my truck, made a world of difference in the handling!! I got it off a camaro Z28, bolted right up, just had to make some spacers for the frame.
I AM CANADIAN!!!!! 1969 Chevy C/10 Truck - SBC V8, TH-350, 3.73 Posi, 1000W Rockford Fosgate Stereo System, B&M Megashifter, GT Grant Steering Wheel, Dual Magnaflow Exhaust System, Dynomax Headers, Lowered 1" Front & 3" Rear, Front/Rear Sway Bars, Racing Seats, 6000K HID Headlights 2008 Chevy Colorado LT - 3.7L I5, 4 Speed Automatic, Crew Cab, 4X4, Z71 Off-Road Package, "Ground Effects" Package, K&N Cold Air Intake, Supermod PTB, Magnaflow Exhaust w/ Resonator, 500W Kenwood / Rockford Fosgate Stereo System, Custom LED Lighting, 6000K HID Low's / High's, Blackcat Customs Gauges / Needles, Carbon Fiber Interior Accents, KrFabs 2" Lift Shackles / Torsion Bar Crank with Rancho RS5000 Shocks, Superskids Skid Plates |
08-15-2012, 07:56 PM | #6 | |
- 1967 Chevrolet C/10 SWB fleetside (New Project). - 1969 Chevrolet C/10 SWB fleetside (SOLD) - 2000 Ford Mustang 232 (DD) - 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver) |
08-17-2012, 11:54 AM | #7 | |
Love That '69
I'd have to take some....
http://www.low69cst.freeservers.com/CamaroBar.htm It's what I used when I installed mine....was a larger diameter bar off a late '80s IROC
08-17-2012, 12:35 PM | #8 |
i got one off a late 80s pontiac firebird and mounted it on mine. i just had to drill a few holes to mount it and no other modifications and it made a world of difference in the handling .i got the bar and brakets from the car and bought new bushing. 30.00 dollars for the bar i think 20.00 for the bushings from oreillys. if you need pictures i will put some on here just reply.
08-15-2012, 07:02 PM | #9 |
Grandpa in the rustmobile...
any pix classic69
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
08-15-2012, 08:34 PM | #10 |
I installed front and rear (& some other suspension parts) and all I can say is WOW!!! Almost no body roll going around corners. Well worth the cost in drivability.
I would like to add that if you plan on any spirited driving you will need to match the front to rear or you will induce over or under steer and quickly lose control. Posted via Mobile Device
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 Last edited by Lee H; 08-15-2012 at 08:43 PM. |
08-15-2012, 09:18 PM | #11 |
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
I have an 84 GMC Serria with a 3/4 ton front bar, a Hellwig rear, all poly bushings, 5/7 drop with spindles and ebiach springs, 17x8 front wheels and 17x9.5 rear with BFG's....the sucker handles like a slot car but rides like a log sled.....basically you're gonna give up ride to get handling to some extent....depends how indepth you go.
08-15-2012, 09:38 PM | #12 | |
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
08-15-2012, 10:09 PM | #13 |
its not that I haven't spent the bucks, I spent plenty, every piece is aftermarket except the front bar....front rides OK, but rear is super stiff with the Hellwig bar, especially over bumps and road irregularities. Not saying its the bars fault....its just doesn't work well with other items I have. I feel its probably more about matching components that complement one another or staying with one manufactures system that is designed to work with one another...rather than simply cubic dollars spent.
08-15-2012, 10:39 PM | #14 | |
08-15-2012, 10:15 PM | #15 |
http://www.summitracing.com/parts/ACO-954/ you guys think this would work or should i get the 1 1/8th size bar?
08-17-2012, 12:35 PM | #16 |
I have a camaro rear bar on my 68
08-17-2012, 03:21 PM | #17 |
Id like pix bonnie/clyde
08-17-2012, 05:37 PM | #18 |
id like to see e pixs to , since putting on rear lowering springs id like to get rid of body rolls my self
08-17-2012, 07:03 PM | #19 |
here are the pics i promised of my rear sway bar from a late 80s firebird.
03-01-2016, 01:28 PM | #20 |
I like the looks of this; after some digging I think it's the Addco 414 bar at 1". I'd like to know the dimensions of the bar though and can't find them, anyone have one of these that could measure?
1968 LWB C20 / AC / Wood Bed |
03-01-2016, 07:06 PM | #21 |
I did they same as 69CLASSIC, mine is off of a 87 IROC
01-12-2013, 12:53 PM | #22 |
Starting mockup of the rear sway bar. I have ordered the splined bar and can mount the bushing brackets then.
1962 Impala SS 383 stroker Tremec TKO 600 Black 1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black 2003 100th Anniversary Road King Classic Silver Black |
01-12-2013, 01:21 PM | #23 |
motor exploder
I've got a late 80's IROC bar too, it's 15/16", vs the 7/8" bar on the z/28's.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
01-12-2013, 04:09 PM | #24 |
the boat guy
Wow nobody has suggested to read the "make it handle" thread.
It really depends how you want your truck to drive. Plenty of autocross guys will remove the rear swaybar..... if you don't know why, go read. Posted via Mobile Device
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
01-12-2013, 07:52 PM | #25 |
I had one installed during my truck's restoration. ( this is the only picture I have, but it can be seen at the very bottom of this picture ) It corners better now and the firmer ride that it has is mostly from the new shocks that replaced ones that were SHOT !!! . . . . |
