Old 08-15-2012, 08:17 PM   #1
tripleh
Unhappy Nv4500
I was needing to know if they installed nv4500 trans in 1986 c30s from the factory? I have 400 turbo in mine with 4.10 axle. Would like a 5speed od to get better mileage. Thks
tripleh is offline   Reply With Quote
Old 08-15-2012, 08:35 PM   #2
legendman
legendman's Avatar
Re: Nv4500
NV 4500 was used in 92 up 2500 and 3500 gm trucks
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 08-15-2012, 08:36 PM   #3
donut
donut's Avatar
Re: Nv4500
To my knowledge, the nv4500 didn't come until later (post square?).
Wish there were installed into squares, it would make the swap much easier.
OD would be nice, but a C-30 and mileage really don't go together. What are your goals and expectations?
Many more knowledgeable people here, I'm sure someone has done the swap.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 08-16-2012, 11:59 AM   #4
Keith Seymore
Keith Seymore's Avatar
Re: Nv4500
Correct.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-15-2012, 09:55 PM   #5
tripleh
Re: Nv4500
I am looking to get 16mpg, 5.7 eng.
Old 08-16-2012, 02:51 PM   #6
Edahall
Re: Nv4500
Do you tow? If not, there are other ways to achieve that fuel mileage figure without having to go through so much trouble.
Example:
3.08 gears
low stall torque converter
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 08-16-2012, 05:24 PM   #7
spencer_41188
spencer_41188's Avatar
Re: Nv4500
http://www.tellico4x4.com/index.php/cPath/4519_4535
cheapest place online that i have come acrost for the nv4500
here in a fue mounths i will start a post on the swop. this winter is gana be a big one 2wd to 4wd convertion, nv4500 swop and fast ez efi install on my 383 stroker and im also puting 3.73 gears in got 4.10s now
the key to fuel economy is making your engine work less. and you wouldn't beleave how bad a carb is on mpg's because of a dirty filter
cfm's is a big deal let the engine breath it will make more hp's and the engine dosnt work as hard
anyway i got alot of info and dont wont to spoil the fun
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker.
spencer_41188 is offline   Reply With Quote
Old 08-16-2012, 06:24 PM   #8
tripleh
Re: Nv4500
where would I get 308s for the 14bolt-10.5 axle? Thks
Old 08-16-2012, 07:02 PM   #9
spencer_41188
Re: Nv4500
you can only get 3.21, 3.42, 3.73, 4.10, 4.56, 4.88, 5.13, and 5.38 ratios for the 10.5 14bolt
Old 08-16-2012, 09:06 PM   #10
tripleh
Re: Nv4500
where is the place?
Old 08-16-2012, 09:37 PM   #11
kwin
kwin's Avatar
Re: Nv4500
The previous owner of my burb swapped to taller gears, not great for acceleration but I get 21mpg highway.
kwin is offline   Reply With Quote
Old 08-16-2012, 11:47 PM   #12
bowtiemanchevyman
bowtiemanchevyman's Avatar
Re: Nv4500
i have a 82 that has 33 and runs 3.73 with a four speed and i get 16 to 18 going 75 down the road so u might want to look in to tuning your motor to run the gears you have so that it is making the best power where u want it to be. in the lows for towing or in the middle for highway or top end.
bowtiemanchevyman is offline   Reply With Quote
Old 08-17-2012, 05:55 AM   #13
tripleh
Re: Nv4500
Can anyone tell me where to get 321 oem gears for the 10.5?
Old 08-17-2012, 09:25 AM   #14
JPalmer81
JPalmer81's Avatar
Re: Nv4500
Go to your local transmission and gear shop. There are numerous places to get them online, but since you don't know where to get them I am assuming that you have never changed gears and it is a very involved process requiring specialty tools that you should leave to the professionals. Not saying you can't do it, just would hate to see you spend money to see it rattling around in your diff after you move a few feet.
One thing you should know is that it is expensive to have your gears changed, a simpler way might be just to get a lift and install bigger tires. That essentially does the same thing a gear change does, but in most cases, is a lot cheaper.
1988 Chevy Crew Cab 1ton 4x4 SRW LWB
1977 Dodge 1 ton 4x4
My Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=516872
"The price of Freedom is Eternal Vigilance"
JPalmer81 is offline   Reply With Quote
Old 08-17-2012, 10:59 AM   #15
legendman
legendman's Avatar
Re: Nv4500
x2 I did gears in a 10-bolt rear once, and it was a pita, the mesh of the gears need to be right on or the gears will howl.
Old 08-17-2012, 04:17 PM   #16
spencer_41188
Re: Nv4500
my gear change is costing me $1200 and thats for a dana 60 and a 14 bolt plus a locker for the rear and a spool in front
your on the right track with the manual trans because you lose power transfer threw the tq converter this is why you can idle and hold the break in gear changing the stall speed will efect that
if you plan on getting a nv4500 i would get a trans tunnal out of a 4x4 blazer (its bolt in) and weld the 4x4 stick hole shut and cut your shifter hole out its about 4" farther back then the sm465 and you will have to put a clutch peddel and master cylender in. not alot involved just time consuming
Old 08-17-2012, 04:28 PM   #17
legendman
legendman's Avatar
Re: Nv4500
Here's a thread on a 4wd swap but it will some idea on what's involved
http://www.dieselplace.com/forum/sho...ghlight=nv4500
