08-17-2012, 12:11 AM | #1 |
Is my flex plate on backwards?
I am having a bad feeling about this, and I think it is but I need some re-assurance. If so what are the issues? I have been having a starter problem!
1968 C10 SWB Dropped 5 in tha back 3 in tha front My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902 |
08-17-2012, 12:14 AM | #2 |
Re: Is my flex plate on backwards?
Pics...
08-17-2012, 12:26 AM | #3 |
sorry dude,,,epic fail!! (it's definitely on backwards)
Wade , JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!! , Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570 Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro |
08-17-2012, 12:25 AM | #4 |
I'm afraid she's in backwards. I do believe the raised portion where you have the bolts going through - that raised portion should be on the torque converter side. This vid might help - take a look at time 00:40-00:50 to see what I mean.
Putting it in backwards will effectively move the ring gear of the flexplate aft - and by the witness marks on the ring gear from the starter, it would appear that's the case becuase it looks like it's only partially engaging on the forward edges of the teeth - assuming the starter solenoid is pushing the starter gear out the normal amount. Careful many more turnovers and you'll probably ruin the flex's ring gear. But, the real answer/tell-tale sign is the side that the indentations are on. Indented side of the flex bosses should face the engine, not the torque converter. Sorry man, that stinks. Don't rip it apart til you get another opinion on here - but that's what it looks like to me. |
08-17-2012, 12:29 AM | #5 |
GRRRRR!!! I knew it, I just didnt want to hear it! Back out with the tranny...
08-17-2012, 12:41 AM | #6 |
It's not the best way but I have changed flexplates by just sliding the trans back a couple of inches on some vehicles. Sometimes a torque wrench won't fit so the bolts get torqued by feel with a box wrench. Like I said not the best method but...
08-17-2012, 01:00 AM | #7 |
Really not that hard, swap out the top bolts for longer shoulder bolts, slide it back on the bolts and then flip the flex plate........yep, I did the same thing.
1971 chevy c10 ECE 4.5/6 dropped 1970 suburban ECE 4/6 Dropped 45K original miles so far 1948 Ford Sedan 1941 Dodge COE 1932 ford roadster the rest are normal drivers |
08-17-2012, 06:05 PM | #8 |
08-17-2012, 01:32 AM | #9 |
That sucks, hope you didn't warp it.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
08-17-2012, 08:47 AM | #10 |
For the cost I wold not reinstall it. buy a new one
08-17-2012, 11:29 AM | #11 |
Florida Edition
Yep, get a new one.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
08-17-2012, 11:35 AM | #12 |
Yea looks like there about $60, so I will gran another one.
08-17-2012, 11:45 AM | #13 |
C10 addict
If the teeth on the flexplate are still in good shape I don't see why you would need a new one. Hopefully you weren't driving it like that, the torque converter isn't properly engaged inside the transmission and could cause issues.
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS |
08-17-2012, 01:43 PM | #14 |
72 GMC
One learns by asking questions.
Why does he need a new flexplate if it was on backward for a short time ? What causes the issue that makes it need to be replaced ? Thanks |
08-17-2012, 06:08 PM | #15 |
Even if the starter ate up the edge of the flex plate ring gear, it wouldnt matter after he puts the flywheel on 180 degrees (correctly) as the bad part would then be on the back side away from the starter. If anything it might have messed up the bendix gear. Even that is not tto expensive if you can find a mom and pop store to seel just the gear. Most chain stores look at you like you just got off a space ship when you ask for something like that!
08-17-2012, 01:38 PM | #16 |
No it hasnt been driven at all, only starter for about 45 seconds.
