08-17-2012, 09:32 AM | #1 |
Truck leans to one side?
Ive got a 70 stepside short bed 1/2 ton that ive owned for a few months now. Ive noticed that if you look at the truck standing about 10 feet behind the back that it leans to the left (drivers) side. The left side is lower than the right side. What might be causing this? shocks/springs are relatively new but i figure i could swap those out as a starter. anyone else ever had that issue?
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 |
08-17-2012, 10:02 AM | #2 |
Re: Truck leans to one side?
it is a very common thing on old trucks due mostly to 40years of hard work the frame has taken a set it is twisted// sometimes by shimming bed and or cab can make it less noticable
08-17-2012, 10:15 AM | #3 |
I had the same problem on my truck. New springs and no more problem.
67 C10 swb bored out 350 granny 4 speed I come from a long line of moonshiners |
08-17-2012, 10:20 AM | #4 |
It is the infamous Chevy Lean. Most Chevy trucks have the problem, and my bet would be the truck has been lowered?
S10's have it, C10's .. I think it's in the way Chevy designed the trucks. I know it's goofy but search the forums for Chevy Lean and you'll find some stuff. I promise.
08-17-2012, 10:38 AM | #5 |
Moderator
Yup, Chevy lean. Most trucks 40 yrs old have it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
08-17-2012, 11:08 AM | #6 |
I had an '85 K10 that was only ten years old and it leaned...the '71 leans....I just try to park on a slope :-)
'65 GMC Suburban 4X4, '71 GMC 4X4 LWB - The Yellow Eyed Monster, '86 C10 Silverado - Oldest Daughter's Pickup, '88 S15 GMC Work Truck, '95 GMC SLE 4X4 - Second Daughter's Truck, '99 K1500 GMC Suburban Road Trip Machine, 2000 C2500 W/T Utility Bed Work Truck, '03 Silverado - Wife's Grocery Getter |
08-17-2012, 11:29 AM | #7 |
just for example --
http://www.355nation.net/forum/lower...-use-them.html If you google 'Chevy Lean Belltech' they make a spacer you can put on the top of the spring on the driver's side and correct the problem. (driver's side up 7/16" makes the rear correct itself too) I used the S10 spacer on my white truck and it worked perfectly. (96 4.3 Ext cab) While yes, this is an S10 I'm referencing as you can see even the new Coloroados / Canyons have it. Just my opinion I think it's by design to compensate for the torsional regidity of the frame / engine mounts. I'm sure people smarter than me would know exactly why but when I drop a truck I usually have the spacers handy for this reason.
08-17-2012, 11:46 AM | #8 |
Newbee
It's not leaning, it's hiking it's leg!
08-17-2012, 11:52 AM | #9 |
It's all in the timing
Is it parked next to a ford.
The Dude Abides. ---------------------- I aint sayin, I'm just sayin. |
08-17-2012, 02:02 PM | #10 |
My old truck (03 Ranger) had a lean as well. Lot's of them had it, known as the Ranger lean. I can't recall exactly, but I think it was due to the gas tank, battery and weight of driver all on one side of the truck.
My suburban has it too, but it leans to the right. Putting some air in my tires helps a little, but not 100%. Good to know some new/fresh springs can help out.
-Nathan- 1972 GMC K2500 Suburban "The Project" 2013 GMC Sierra 1500 SLT Z71 "The Daily Driver" 2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD 1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD 2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD |
08-17-2012, 02:06 PM | #11 |
Broke and still trying
Mine leans also, but maybe because I'm from Oakland.
08-17-2012, 02:20 PM | #12 |
A big ole woman would fix it too.
08-17-2012, 02:29 PM | #13 |
08-17-2012, 03:28 PM | #14 |
yall are funny! thanks for the info though. im still gunna probably throw some new shocks/springs in there when i do my front disc converstion soon though.
08-17-2012, 05:11 PM | #15 |
My cab was leaning to the right. Turns out the rubber cab mounts were shot on that side.
Had to add some washers/shims to the new mounts to make things level and match the body lines. |
08-17-2012, 05:15 PM | #16 |
never thought of that either! i guess ill be able to get a closer look when i do the rear shocks/springs
