Old 08-20-2012, 01:42 PM   #1
gerrygos
Brake upgrade for 71 Suburban
Hey Guys,
Would like to know what parts, beside brake
shoes and drums, are needed to change from
a 2" x 11" to a 2 3/4" 11 5/32" rear brake unit.
Thanks in advance,
Gerry
gerrygos is offline   Reply With Quote
Old 08-20-2012, 02:04 PM   #2
69gmcc10
69gmcc10's Avatar
Re: Brake upgrade for 71 Suburban
Gerry,
Welcome to the board!
The upgrade to 2.75" brakes involves the drums, shoes and the backing plates that mount to the axles. The larger brakes use recessed backing plates to move the drums over the axle more so that the track width is not changed on the rear end. I found the entire assembly (drums shoes and backing plates) at a junk yard for $40 each. If you go this route measure to make sure the drums can be turned so you can reuse them. The break lines will also need to be modified or replaced because the break cylinders on the 2’ and 2.75” are slightly different.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 08-20-2012, 04:21 PM   #3
69gmcc10
69gmcc10's Avatar
oops, I mean $40 total
