Old 08-24-2012, 11:51 PM   #1
79 blue monster
79 blue monster's Avatar
new rearend
picked up a rearend out of a 80's c30 CC truck for $150 and am going to put it under my 79 3/4ton.(4in narrower than mine) now i was told everything will work just fine, but the brakes will just stop alot quicker because their made to handle duals, not singles. is this true, and will their be any other problems? thanks in advance
1979 GMC 3/4 ton camper special 454 (7/8in drop) UPDATE: CADDILAC 500 SWAP AND 4X4 SWAP
http://67-72chevytrucks.com/vboard/s...d.php?t=518625
1965 gmc 4x4 build : http://67-72chevytrucks.com/vboard/s...d.php?t=724972
79 blue monster is offline   Reply With Quote
Old 08-25-2012, 01:02 AM   #2
wyattglock
wyattglock's Avatar
Re: new rearend
It probably will stop quicker. If you can get the wheel cylinders to hold up, which may be easier since you are evidently planning on a single rear wheel setup. Make sure you rebuild the drums before you put it on, it will save you a lot of work under the truck.
wyattglock is offline   Reply With Quote
Old 08-25-2012, 02:21 PM   #3
sqzbox
Re: new rearend
Hope you got th same lug count, 8 lugs front and rear.
sqzbox is offline   Reply With Quote
Old 08-25-2012, 04:30 PM   #4
79 blue monster
Re: new rearend
yup, my lowered truck is a 3/4 ton. and ok i'll probibly open it all up, clean it all out it all and repaint it up nice.
