Old 05-24-2003, 09:55 PM   #1
matt_field
matt_field's Avatar
still smoking, now what
alright, my truck still smokes when you step on it, and now it pours out antifreeze out of the overflow hose on the radiator. did overheat till i threw out the thermostat now it stays cool just overflows. anyone?
matt
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 05-24-2003, 10:03 PM   #2
ddsmith
Glowing since 1978
ddsmith's Avatar
Sounds to me like compression gasses are leaking into the coolant and it's head gasket time. Hope that is not the case but if your building that much pressure that is the likely source.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 05-24-2003, 10:05 PM   #3
matt_field
matt_field's Avatar
could it be rings? or cracked head as well? this stupid motor has given me more troubles once i bought it. thanks
matt
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 05-24-2003, 10:32 PM   #4
cdowns
cdowns's Avatar
sounds BAD looks like it's got to come out and either be replaced or rebuilt if it's rebuildable
Old 05-24-2003, 10:36 PM   #5
matt_field
matt_field's Avatar
great.. well for around 1,000 i can get a new 350 in the bag still complete. i might have to part mine and put everything on that and get it for cheap
thanks
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 05-24-2003, 11:02 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
head or head gasket
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-24-2003, 11:04 PM   #7
matt_field
matt_field's Avatar
thanks guys, ill be pulling the head tomorrow and see whats going on inside, i bet head because this kind of head are usually cracked (461 camel backs) either be replacing or getting fresh 350. im sick of messing with it and not being able to drive this truck its all done this is pissin me off thanks again
matt
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 05-25-2003, 12:01 AM   #8
too much stuff
Roadtrip!
too much stuff's Avatar
heads
Not very often you see a cracked camelback.
too much stuff is offline   Reply With Quote
Old 05-25-2003, 04:27 AM   #9
jimfulco
Put a good thermostat in it.
jimfulco is offline   Reply With Quote
Old 05-25-2003, 01:40 PM   #10
chaptr2
chaptr2's Avatar
Have you done the compression check yet? You said you were going to do that this weekend. What did you find?
Where is the smoke coming from?
This is only my opinion and it is subject to change.
70 GMC Short box stepside Blown 388 Stroker
72 K/5 Blazer 350/SM465/205
chaptr2 is offline   Reply With Quote
Old 05-25-2003, 11:34 PM   #11
matt_field
matt_field's Avatar
never ran compression test, but me and my dad figured out its the head cracked or gasket, well i took the head off today and found a bolt that was finger tight and the rest are not torqued, gasket is shot, putting new gaskets in on tuesday and getting heads surfaced and maged. also the 461 camel backs usually are cracked. i read that all over on the net. and also my machinest said that also as i did have a pair cracked before i bought this motor. thanks
matt
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 05-25-2003, 11:52 PM   #12
bigjimzlll
bigjimzlll's Avatar
The reason the 461s are found cracked is...they're 40 years old and have been hotrodded to death..and been abused(as in your case) They were very sturdy castings
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
