08-28-2012, 09:17 AM | #1 |
Wtb 4.56
Want to buy 4.56 or 4.88 Ring & Pinion for 12 bolt truck or willing to trade my 3.73 R&P for one.
'71 LWB c10-"WORK" in progress 385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall 2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better) 2013 best 7.39 2014 best-7.38 New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage Last edited by skeeterbug; 09-10-2012 at 07:56 AM. Reason: additional information |
09-04-2012, 02:39 PM | #2 |
Re: Wtb 4.56
Bump
'71 LWB c10-"WORK" in progress 385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall 2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better) 2013 best 7.39 2014 best-7.38 New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage |
09-04-2012, 06:04 PM | #3 |
Re: Wtb 4.56
I have a whole rear 5 lug 4.56 with a richmond posi - but i am in Texas
but reading your times on the 8th brings back memories. ttt for ya |
09-10-2012, 07:57 AM | #4 |
Re: Wtb 4.56
ttt
09-24-2012, 09:59 AM | #5 |
Re: Wtb 4.56
bump
09-24-2012, 04:15 PM | #6 |
Re: Wtb 4.56
I have a new gearset from Dana $150.00 plus shipping. Also have Master Kit, comes with all the bearings, shim kit, crush sleeve, seal and nut for $225.00 plus shipping.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
09-25-2012, 01:38 PM | #7 |
Re: Wtb 4.56
70STOVEBOLT thanks for the reply, is that a Dana brand gear set to fit a chevy 12 bolt truck rear axle? If so whats the ratio, i already have a yukon master rebuild kit minus pinion seal from a posi upgrade.
thanks, skeeterbug
09-26-2012, 10:49 AM | #8 |
Re: Wtb 4.56
Skeeterbug, it is a Drivetrain brand that Dana was marketing back in the 90's. I have one 3.07 ratio, two 3.73, two 4.10 and one 4.56. $150.00 is for the ring and pinion only.
Thanks, Mark
09-28-2012, 07:44 AM | #9 |
Re: Wtb 4.56
So just to clarify it [B]will [B]fit my 12 bolt truck rear end correct? If so do you know the shipping to 37184.
09-28-2012, 10:25 AM | #10 |
Re: Wtb 4.56
Yes it fits 12 bolt truck differential 1/2 & 3/4 ton 1964-72 with 8.875 ring gear diameter. It will fit in a large flat rate box so $15.00 shipping.
