Old 08-28-2012, 12:48 PM   #1
greatdane
greatdane's Avatar
thinking about lowering my 84 swb
Im thinking about droping my truck 3 & 4. If I were to use 3" spindles up front and a shackle hanger combo for the back. Would my stock shocks be ok?
It is cheaper to go with 3" drop coils up front. What are the pros and cons of that?
Also I have been looking at Crown Suspension. Its priced low, does anyone know of it?
greatdane is offline   Reply With Quote
Old 08-28-2012, 01:01 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: thinking about lowering my 84 swb
Spindles over springs, the ride will be better, especially for a 3" drop. You will need drop shocks, and you should consider a flip in back...most of us who do the shackle/hander drop (including me!), take it back out and put in a flip. If you do go 4" in back, keep your stock hangers just to be safe.
bigblock73 is offline   Reply With Quote
Old 08-28-2012, 01:03 PM   #3
cory d
cory d's Avatar
i would go with spindles and a flip kit, that way WHEN you want to go a couple inches lower. it will be cheap and easy with cutting one coil and drop shackles or hangers
cory d is offline   Reply With Quote
Old 08-28-2012, 01:26 PM   #4
boatpuller
boatpuller's Avatar
That truck will look cool lowered.I did a 4/6 belltech kit.3 in drop spindles and 1 in coil's.In back a flip kit and c notch get's you 6. Iv'e been very happy with the ride.It came with nitro shocks.I'm not sure if that's a belltech product or not.Good luck with it and post a pic or two when you drop it.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 08-28-2012, 01:34 PM   #5
77ChevySharkBite
77ChevySharkBite's Avatar
I know its a different year model and all but I'm looking to do a 3/5 on my 77 but the only thing that's different is I'm actually going to be buying new shocks for the whole truck should i still use shackles for the front?
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 08-28-2012, 02:48 PM   #6
greatdane
greatdane's Avatar
Think I will get some 3" spindles!
Im pretty set on a 3-4 drop for now. I dont want/need it real low. Do you have to remove the bed to install the hangers? I have access to a lift.
Will any "drop shock" work? Or do they have to match ther parts you have?
Sorry guys I have never lowered anything before!
Old 08-28-2012, 03:36 PM   #7
greatdane
greatdane's Avatar
BUT after looking around a 5" flip sounds easy enough? Maybe go 4-5?
Old 08-29-2012, 10:12 AM   #8
greatdane
greatdane's Avatar
Thanks! I hope it turns out ok.
If you do a 3, 5 drop won't the back be lower than the front? I dont like that look! I want level or slightly higher in the back... guess if it didnt look right could always cut a coil or buy drop coils. But I would rather do it right the first time. I would like to see a 3, 5 drop anyone got that on here?
77 sb: Google search toxic shocks you will find a vendor. Maybe ebay?
1993 Silverado C2500 Single Cab LWB
2007 Chevy Silverado 1500 Crew Cab LTZ 4x4
1974 AMC Matador Coupe - The Mat
Old 09-19-2012, 11:10 AM   #9
greatdane
greatdane's Avatar
Went ahead & ordered 3" DJM spindles and 4" shackles and hangers.
Questions:
Can you use your stock shocks with this set up? Do you have to change anything else besides the spindles in the front like.....like brake lines? Just don't want any supprises...
Please post some pics of 3/4 drops or if there is a thread on here about it.
Old 08-29-2012, 10:21 AM   #10
baclay9
Mine is lowered 5/7. If I sit a level on my bed rail it is perfectly level. These trucks sit 2" higher in the back. It is deceiving because the fender openings are not the same height front to back.
baclay9 is offline   Reply With Quote
Old 08-29-2012, 10:30 AM   #11
splehigh
splehigh's Avatar
Nice truck. I've always liked that paint scheme.
splehigh is offline   Reply With Quote
Old 09-19-2012, 11:44 AM   #12
rs74
rs74's Avatar
How much of a drop can you do before one has to do a c-notch. I have thought about dropping mine but don't want to notch it. Just looking for it to get lowered with the best ride possible.
Also there was a guy around here that put some sort of cadillac suspension under the front of his but not sure what components he used to make it happen. He said it made the ride alot nicer although it wasn't lowered.
rs74 is offline   Reply With Quote
Old 09-28-2012, 07:26 PM   #13
greatdane
greatdane's Avatar
Lowered
Old 09-28-2012, 07:31 PM   #14
greatdane
greatdane's Avatar
3 & 4
Old 09-28-2012, 10:03 PM   #15
jrblanke
Saaahh weeeet!
jrblanke is offline   Reply With Quote
Old 09-29-2012, 11:03 AM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
3 & 4
That looks sooo much better. What kit did you end up with?
It looks like it sets pretty level. If you want a bit of rake, consider cutting a half coil and see if you like it.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-29-2012, 11:30 AM   #17
Malo83
Cruzzzn' Vet
Malo83's Avatar
Knockout
What is your tire/wheel pkg?
Malo83 is offline   Reply With Quote
Old 09-29-2012, 10:37 PM   #18
greatdane
greatdane's Avatar
Originally Posted by Malo83 View Post
Knockout
MB Old Schools - 17x8's with 275/55/17's all the way around & a 3/4 DJM drop kit
Old 09-29-2012, 10:33 PM   #19
greatdane
greatdane's Avatar
[QUOTE=N2TRUX;5619235]That looks sooo much better. What kit did you end up with?
It looks like it sets pretty level. If you want a bit of rake, consider cutting a half coil and see if you like it.[/QUOTE
Thanks!
DJM - 3" spindles & 4" Hangers & Shackles. It is level, I put a 4' level down the bed & its dead on. I might cut a 1/2 coil later but Im going to run it like this until I get it painted.
Old 10-09-2012, 03:56 PM   #20
greatdane
greatdane's Avatar
Well I went ahead & ordered some 2 inch drop coils from Brothers, that should rake it out! Hope my tires don't end up rubbing the fenders! Think 2" will be to much?
Old 10-14-2012, 10:20 PM   #21
greatdane
greatdane's Avatar
5 & 4
Old 10-14-2012, 10:27 PM   #22
greatdane
greatdane's Avatar
5 & 4
Ok now...
Old 10-14-2012, 10:46 PM   #23
jrblanke
Awesome dude! Looks killer!
Old 10-15-2012, 12:23 AM   #24
INSIDIOUS '86
INSIDIOUS '86's Avatar
Lower!!!
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-15-2012, 11:55 AM   #25
greatdane
greatdane's Avatar
Nah, I'm done with it suspension wise. I like em raked out!
