08-28-2012, 03:42 PM | #1 |
67-72 parts collector,…
Disc Brake Front Parts List by Year
This info is found at the very end of this thread:
http://67-72chevytrucks.com/vboard/s...68&postcount=4 As these trucks get older and changes hands from owner to owner,... I get more and more PM's about people trying to figure out what the previous owner has done to his truck. It use to be, that all the drum brake 60-70 trucks we buy still have the drum brakes up front. I'm seeing an increasing number of questions coming from members that have a truck with disc brakes already installed. Most are fine. 71-72 parts swapped, or 73-87 parts swapped. But some are kind of scarey. Just because parts bolt together doesn't mean they are correct. (I will fill in some missing info as soon as I can) Again,... here's the breakdown of the front end parts by year: Disc Brake Spindle: *60-70 (Aftermarket Conversion Spindles) *71-72 (oem or drop) *73-87 (oem or drop) C10 Grouped by Differences: *60-62 *63-70 *71-72 *73-87 (HD 1.25" wide rotors) *81-87 (LD 1.00" wide rotors) **Some 81-87 trucks also had the HD rotors** ** All Aftermarket 6-lug "Conversion Rotors Are the HD 1.25" wide version** C20 *71-87 Rotors: C10 *71-72 (1.25" wide) *73-87 (HD 1.25" wide rotors) *81-87 (LD 1.00" wide rotors) **Some 81-87 trucks also had the HD rotors** ** All Aftermarket 6-lug "Conversion Rotors Are the HD 1.25" wide version** Calipers: C10 *71-72 (1.25" wide) *73-87 (HD 1.25" wide rotors) *81-87 (LD 1.00" wide rotors) **Some 81-87 trucks also had the HD rotors** ** All Aftermarket 6-lug "Conversion Rotors Are the HD 1.25" wide version** Upper Ball Joint: Grouped by Differences: C10 *60-62 *63-70 *71-72 *73-87 C20 *71-87 Lower Ball Joint: Grouped by Differences: C10 *60-62 *63-70 *71-87 C20 *71-87 Control Arm Upper Cross Shafts: Grouped by Differences: C10 *60-62 *63-72 *73-87 C20 *63-87 Control Arm Lower Cross Shafts: Grouped by Differences: C10 *60-62 *63-72 *73-87 C20 *67-87 Inner Tie Rods: Grouped by Differences: C10 *60-62 *63-64 *65-70 *71-72 *73-87 C20 *60-64 (drivers side) *60-64 (pass. side) *65-70 *71-87 Outer Tie Rods: Grouped by Differences: C10 *60-64 *65-70 *71-72 *73-87 C20 *60-64 *65-70 *71-87 Tie Rod Adjusting Sleeves: Grouped by Differences: C10 and C20 *60-64 *65-70 (5/8" thread) *71-87 (11/16" thread) Centerlink: Grouped by Differences: C10 *60-62 *63-64 *65-70 *71-72 *73-87 C20 *60-64 *65-70 *71-72 *73-87 Pitman Arm: Grouped by differences: C10 *60-66 Manual *60-66 P/S *67-72 Manual *67-87 P/S (Specify Year When Ordering) C20 manual: *60-66 *67-68 *69-70 *71-87 Power Steering: *69-70 *71-87 Idler Arm: Grouped by differences: C10 *60-62 *63-66 *67-82 *83-87 C20 *60-66 *67-82 *83-87 Steering Box: Manual *60-62 *63-66 *67-87 Power Steering
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-19-2013 at 10:50 AM. |
09-05-2012, 11:47 PM | #2 |
Active Member
Re: Disc Brake Front Parts List by Year
ok, I'm so lost/confused as what I need to do to swap my 69 3/4 ton 8 lug drums for disc...I was told I can simply just buy a whatever yr 67-72 truck disc parts as long as it came from a 3/4 ton or c20. I know I need spindles,rotors and calipers but what else? And is that true about as long as it came from a c20 or 3/4 ton I'm ok? Also what are my options for the rear? I think I have the eaton rear end. but not even sure about that...well any help you can give is very welcomed...As I'm not sure what I need...
thanks, Betty |
09-06-2012, 06:09 AM | #3 | |
(or 73-87 C20 truck) You need everything from the a-arms out. I would also get all the steering linkage. The 71-72 Master Cylinder and prop valev will work the best. Are you just planning on swapping 40 year old parts onto your truck,... or are you rebuilding EVERYTHING as you go? Do you have P/S? Are you wanting disc brakes for the rear also?
09-06-2012, 01:18 PM | #4 |
Active Member
my steering stuff that PO included...
Also the pic. with the red circle...the boot or whatever you call it looks like its leaking. So how do I replace that? and how? thanks, Betty P.S. Thanks for all your help... |
09-05-2012, 11:56 PM | #5 |
C/10 junkie
Once again very valuable and great info. Thanks Keith.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
09-06-2012, 01:13 PM | #6 |
Active Member
hmmm so i can't just swap out the spindles,rotors, calipers,and brake hoses?
My a arms won't work? Now I did aquire lmc truck parts these are the part numbers.. 2- #34-2024 Outer tie rod end 2- #34-1924 Inner tie rod end 2- #34-1124 Adjuster sleeves w/ pwr str. 1- #34-2120 Idler arm will these still work for me? why would I need the steering linkage? and what part is that exactly? I don't currently have power steering or brakes...but when I bought truck PO included a steering shaft and gearbox ( i will attach those pics) I am also wanting to add power brakes too. Now let me ask this about the power brake option..can I just buy the brakets and bolts with support arm and then buy from autozone the master cylinder and brake booster? I seen someone asking on here for the "rod" would I need that or would it come with the booster? Cause if I can buy new and local I eliminate shipping costs and possible duds... And yes I am wanting to add disc to the rear as well...maybe and probably not right away but at some point. betty |
09-06-2012, 01:53 PM | #7 |
I'll try to answer your question in detail later when I get home.
Ball joints, tie rods, centerlink, adjuster sleeves are different. Your a-arms are the same. Anyone else care to jump in and help?
09-06-2012, 02:17 PM | #8 |
Active Member
ok, sounds good and thank you...sorry if I'm asking to many questions and stressing you out... but like I said I have no clue...lol I'll clearly wear the dunce cap here..( or dumb chic cap) lol
betty |
09-06-2012, 03:24 PM | #9 |
This is great info. Thank you.
Can someone comment or add the interchange for ball joints to a-arms. For example, can I mount 73-87 ball joints on 63-70 a-arms? What are the year breakdowns there? Thanks! |
09-06-2012, 04:04 PM | #10 | |
All the 1/2-ton LOWER a-arms will interchange 1/2-ton only balljoints. (63-87) And all the 3/4-ton LOWER will interchange 3/4-ton only ball joints. (63-87) (the 3/4-ton balljoint hole, in the lower a-arm, is larger than the 1/2-ton version)
09-08-2012, 12:50 PM | #11 |
Awesome, thanks.
01-19-2013, 10:59 AM | #12 |
Bringing this back to the top.
I had a member PM me this week asking about 73-87 idler arms. The parts stores (local and online) show 2 different part numbers. The part number break is: 67-82 83-87 So I stopped by my local parts store to see what the deal was. The 67-82 version is the same on both ends. The 83-87 has one end of the idler arm, that is smaller. So I assume the 83-87 (and 88-91 2wd burbs) have a smaller hole in the idler arm "frame bracket". (because all the 73-87 centerlinks are the same) Before I could PM the member,... he had already done the same thing at his parts store,... and had sent me a PM to confirm what I had found. I really appreciate his efforts. I adjusted my original post to reflect what we found. If anyone else sees an error on the above list,... please bring it to my attention. I just want to get the correct info out there!
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-20-2013 at 10:05 AM. |
01-20-2013, 09:51 AM | #13 |
Great info.This will be very helpful for me.
01-20-2013, 10:02 AM | #14 |
Great info to keep up with,Thanks Keith
Posted via Mobile Device |
01-20-2013, 10:24 AM | #15 |
Keith thanks alot for putting this list together. This is the stuff and people that makes this forum great.
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
