08-28-2012, 10:30 PM | #1 |
spindle bearing sizes?
are the inner/outer spindle bearings different sizes for light duty and heavy duty?
i ordered bearings from summit.com for a 72 c10 2wd. i got them today and they are to small for my spindles and rotors. i double checked the part numbers with summit and it shows them to be for light duty brakes. i looked at a few other brands they have and their are some for heavy duty brakes. i have cpp 12" diam. x 1 1/4" thick rotors, mcgaughy's 2 1/2" drop spindles, and wilwood d52's. thanks.
Daniel 68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594 Romans 10:13 Everyone who calls on the name of the Lord will be saved. |
08-28-2012, 11:53 PM | #2 | |
Hollister Road Co.
Re: spindle bearing sizes?
08-29-2012, 01:05 AM | #3 |
67-72 parts collector,…
One of the two bearings is different.
I can't remember if it's the inner or outer bearing. Posted via Mobile Device
08-29-2012, 06:12 PM | #4 |
both bearings are smaller than what i need. i'm just going to return them and go to a local bearing supplier that my work uses. that was my original intention, but it's a little to easy to just order off the internet when your already sitting in front of the computer.
thanks guys.
08-30-2012, 07:08 PM | #5 |
i picked up a set at o'reillys today. here are the different part numbers on the boxes incase it helps someone else.
national/moog - outer, A-3, D28-18700 or 2M12086 national/moog - inner, A-5, D28-18701 or A 12101 inner seal - national/moog - 8871
Daniel 68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594 Romans 10:13 Everyone who calls on the name of the Lord will be saved. Last edited by suspect; 08-30-2012 at 08:32 PM. |
