05-25-2003, 10:09 AM | #1 |
location of sport mirrors on doors
I'm taking the origional camper mirrors off my '72 GMC truck and putting the sport mirrors on. I've heard the loaction was a little different on both doors . Does someone have a truck that came with the sport mirrors from the factory?Can someone please measure from the front door to the mirror and give me the measurements so I know the horizontal measurement on both doors and tell me the measurements on the flat area where the mirrors mount and tell me how much room there is the below the mirror and above the mirror in this flat area, so I know the vertical measurement. Thank you everyone.
05-26-2003, 01:24 AM | #2 |
According to the factory assembly manual, there needs to be a "reinforcement assembly" on the inside of the door that I guess would be there to help hold the mirror arm on securely. It does not give the measurement from the door edge to the screw holes though. However, to give you a rough idea of where the mirror sits, the 2 back screws for the mirror are pretty much lined up under the vent window frame between the 2 top body crease's (if thats the right term!) I don't know if your truck would have the "reinforcement" for the 3 screws,if it came with the camper mirrors originally, maybe not- but you might be able to use a flat piece of steel behind there to button it all down if you use machine screws with nuts and washers. I'd post a picture for you on here if I could, maybe someone else could do this-the mirror diagram is almost at the back of the manual, about 40-50 pages from the back. Hope this helps-KEEP ON TRUCKIN!!!!
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart 1998 Chevy 1/2 ton ex cab V-6 5 speed 1967 Chevy SWB - project truck; not started just yet |
05-26-2003, 10:57 AM | #3 |
If you measure trucks with factory mirrors, you will note that there is some variation as I believe that they layed these out and drilled them by hand.
This is the way we install the mirrors based on measurements that we use. Using the gasket as a template, center the gasket on the flat part of the door where the mirrors mount. On the left side the gasket is 6 1/2" from the front edge of the door. On the right side the gasket is 8" from the door edge. Locate the holes and drill 5/16" holes. (I believe that the factory used 11/32"). To mount we use ss screws screwed into the reenforcements. If you need a pic, I can post one. Jim |
05-26-2003, 11:14 AM | #4 |
What are you going to do with your old mirrors Dave?
