Old 08-29-2012, 02:33 PM   #1
gmech
Deal on U-Bolts
I picked up 4- 2-1/2"x5/8x11-18 U-Bolts for $1.76 ea. on ebay. They were on the Uhaul surplus store page. No nuts or washers though, but for less than $15 I thought that it was not too bad. I got these for my 91 r3500 rear leafs.
gmech is offline   Reply With Quote
Old 08-29-2012, 02:39 PM   #2
gmech
Re: Deal on U-Bolts
Actually they are $1.20 ea.
Old 08-29-2012, 03:21 PM   #3
Ski-me
Ski-me's Avatar
Re: Deal on U-Bolts
Isn't it 3.5" instead of 2.5"? Which axle, 14 SF?
Do you have a link?
thanks!
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 08-29-2012, 07:41 PM   #4
88Jimmy4x4
88Jimmy4x4's Avatar
Re: Deal on U-Bolts
2-1/2 is correct but those are way to long unless you have lift blocks under the leafs
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 08-29-2012, 08:05 PM   #5
Ski-me
Ski-me's Avatar
Re: Deal on U-Bolts
11" would be perfect in my case because of lift blocks. My 10 Bolt measures about 3" in diameter and my 14 bolt measures about 3.5" in diameter. So 2.5" seems small to me.
- Jeff
Old 08-29-2012, 09:05 PM   #6
gmech
Re: Deal on U-Bolts
My truck was actually a V3500 to start with, but I was told that the springs are the same as the R3500. These are the squared type U bolts also. Mine do not rap around the axle tubes, they have a mounting plate for the bottom and a spacer at the top. If you go to gmpartseast and look up 1991 chevy r3500 and go to the frame, spring section you can see what I mean. I measured the springs @4.5" top axle mount to bottom axle mount@ approx 4-1/4" and my spacer that sits on top of the springs @.5". To the threads is 9" in the ubolts, overall is 11.5"
Old 08-29-2012, 09:06 PM   #7
gmech
Re: Deal on U-Bolts
I do not know how to post a link yet or I would have. Sorry.
Old 08-29-2012, 09:23 PM   #8
gmech
Re: Deal on U-Bolts
google uhaul truck parts online and youll get a link.
Old 08-29-2012, 09:24 PM   #9
Ski-me
Ski-me's Avatar
Re: Deal on U-Bolts
Ahhhhh...... forgot about the square u-bolts for that era. Dang!
I took a 2500 axle from a 94' but cut off the perches to go under my older, k5 era truck. Oh well, Mill keep looking!
- Jeff
