09-01-2012, 04:53 PM | #1 |
89 crew cab k20 4wd twin turbo cummins swap
So after months of research and purchasing parts i'm finally digging in. I first got the motor a few years back from a Case IH agriculture sprayer that i bought and stripped after it had been hit by a train. The sprayer flew 90 feet and amazingly the motor was fine, except for the oil pan, pickup tube, and injector lines. I've been wanting to drop the motor into something for a long time. I finally bought a 6" lifted 84 crew cab chevy with the frame already shortened rust free box cab and 1990 suburban power doors and front clip and 468 big block. But i ran into a big problem.. The vin tag for the dash got lost because a new surburban dash was swapped in and the old one was cut out and, well, it disappeared... Then lucky for me a different guy in town was selling his 89 crew cab chevy with 45k original miles that he bought from the Arizona swat force. He removed the bombproof swat center room whatever you wanna call it and installed a flatbed. What's great is it's never seen salt so it's in fantastic condition, inside and out. I sold the bed for $2000 and the engine for $1500 so i don't have much invested in it. Anyway i'm pretty new to these forums so bear with me as i try to get my pics uploaded and more details will come soon.
Before After |
09-01-2012, 04:54 PM | #2 |
Re: 89 crew cab k20 4wd twin turbo cummins swap
My inspiration from youtube with a 24valve.
09-01-2012, 04:55 PM | #3 |
This is where i found her
09-01-2012, 04:56 PM | #4 |
09-01-2012, 05:01 PM | #5 |
Donor cab |
09-01-2012, 05:06 PM | #6 |
Finished motor!
Compound turbo kit is a massive S474 over a phatshaft 62 from industrial injection with a 3 piece manifold. I went with this kit because it's supposed to , as they told me, spool like a mother fuc**er and it looks like it would fit perfect in the c/k body with the large turbo up in front rather then down under the smaller turbo. The whole truck will be painted chevy volt pearl white. I painted the engine red because it's cummins national color and it came from a CaseIH and it just looks awsome! I picked up the p-pump from a pullin truck that was gettin upgraded to a 13mm, so it already has all the goodies. The original AG pump wouldn't work because it didn't have an automotive governor. The old lines were mangled so i got .093 stainless lines to give it some lope. The injectors are SAC 7x14's should be plenty to fuel the turbos. I am building a little motor to connect to the manual fuel plate so i can adjust it on the fly inside the truck so it will be streetable since it will be my everyday driver. I put an adjustable timing gear on the injection pump to help tune things in easier with a custom made billet cover. I polished all the chrome work myself, just took it to a guy i know to have it all dipped. It's very cheap if its prepped and ready to be plated. The clutch is a south bend stage 2 which will be bolted to the dodge nv4500 with a billet 1 3/8"'s input shaft and a 1st gen reman dodge 205 with extreme duty bearings and chevy outputs. I'll get pics of it up later. As for the internals the cylinders have been bored 40 over and fitted with oversized low compression marine pistons. All new bottom end bearings and main and rods bolted together with ARP bolts and studs held together with a girdle. I sent the head out for fire ringing, 60lbs valve springs and titanium retainers and keepers. Here you can see where the old motor mounts broke off the block when the sprayer was struck by the train, lucky for me i don't need those holes. You can see the article of the accident here: http://www.kcrg.com/news/local/3191126.html |
09-01-2012, 05:14 PM | #7 |
Sulastic shackles, makes a 1 ton ride like a cadillac. |
09-01-2012, 05:21 PM | #8 |
ladder bars
exhaust 4" turbo back to the 5" silverline stacks rear bumper mounted Ibeam for weight bracket for pulling |
09-01-2012, 05:29 PM | #9 |
stacks are not straight because they are not tightened. The will also be trimmed flush with the top of the headache rack. Batteries and washer fluid will be mounted in the toolbox.
High temp paint and heat wrapped. King Ranch F-150 seats, not mounted yet. roll cage Dual Fox shocks |
09-01-2012, 05:29 PM | #10 |
give me that truck please ill be your bestfriend for life
1969 chevy camaro Z28 #matchin Factory 4wheel disc 1969 chevy cst10 big block overdrive 5/7 drop dog dishs 1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s 2004 gmc sierra dually 4/4 lowering daily driver |
09-01-2012, 05:32 PM | #11 |
suspension testing : )
Homemade steering assist crossmember Shortened bushwacker fenderflares That's all for now, more pics to come. Thanks, Eric |
09-01-2012, 05:49 PM | #12 |
Well at this rate you should be on the road by noon tomorrow. Killer project!
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
09-01-2012, 10:07 PM | #13 |
This truck looks like its gonna be awesome when finished
Posted via Mobile Device |
09-01-2012, 11:15 PM | #14 |
wow lots a work....all worth it cause your gonna have a killer truck when finished......love it....
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
09-17-2012, 08:58 AM | #15 |
Used a hot pressure washer/sand blaster to strip the frame, then sprayed the frame with a rust converter, then with a rust inhibitor primer, then with gloss black urethane enamel.
While i was waiting for the frame to dry i worked on installing the 2nd gen dodge intercooler. Took a lot of trimming but it fits. |
09-23-2012, 02:00 AM | #16 |
SICK BUILD! Pretty much exactly what I want to build.......but never will get to that point I'm sure. Nice work thus far......impressed.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s 1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater 1963 C10 reg cab long box 1970 Chevelle 1968 Biscayne 2dr post "...there is no excuse for what I am about to do, but dangit....it's gonna be fun!" |
09-23-2012, 12:15 PM | #17 |
this thing is sick, cant wait to see more, id love to this some day
09-24-2012, 09:31 AM | #18 |
Gearhead
Love how well the intercooler fits/fills up the grille, awesome build.
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
09-24-2012, 08:32 PM | #19 |
did you do anything to the park-turn signal lens to fit the i/c there? build is great.
09-25-2012, 12:22 AM | #20 |
Here's an update, installed an all aluminum 3 row radiator mounted and a dual feed fuel line for the injection pump.
09-25-2012, 12:27 AM | #21 |
yea i had to cut out some of the turn signal. The intercooler goes inside the light about 2 inches. I"ll have to fiberglass the hole shut when i'm done.
09-27-2012, 09:26 AM | #22 |
This is turning out awesome. What style intercooler did you use?
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
09-28-2012, 07:12 PM | #23 |
This truck will sure be sweet when its done. I am interested in how those twins sound when they spool. How many inches did those sulastic shackles add to your lift?
09-28-2012, 08:10 PM | #24 |
This looks like it oughtta turn out good, keep at it brother, wont be long now... if you ever need any weird or odd parts, i own about 13 untitled but decent trucks, those years like that, ill sell em to ya at a super low price, or hell! Dependin' on what it is, i might give it to you, just ask, or pm me! keep postin pics
09-28-2012, 08:12 PM | #25 |
This truck is going to be sick, when done. Awesome work so far, engine looks amazing.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD 84 Chevy K30 CC SRW 55 Chevy 210 2dr post |
Tags |
4wd, c/k 30, crew cab, cummins swap, twin turbo |
