09-02-2012, 01:09 PM | #1 |
cooling Help Needed...
Cooling help needed..! I have a 1970 gmc with a 383 stroker with very close to 500 hp. I'm running a TCI Street Fighter 700R4 trans. I have a 3 core rad that measures 28" x 18.5" with trans cooler mounted in front coming through Rad first. I have a 16" flex fan with shroud. I discovered to day that I have been running with no thermostat when I was attempting to replace it. I installed an 180 degree thermostat an im still idling at 230 degrees but highway temp is 190 degrees. I'm thinking I need electric puller fans unsure what cfm, I don't know. Any and all is appreciated, Thanks..!
Posted via Mobile Device |
09-02-2012, 05:58 PM | #2 | |
406 Powered
Re: cooling Help Needed...
70 GMC 68 c10 2002 silverado 72 4x4 |
09-02-2012, 06:08 PM | #3 |
I am using a shroud and I am not using an aluminum but it is a 3 core. The flex fan is only 16"...
09-04-2012, 08:50 PM | #4 |
What do you guys think the optimum operating temp should be..?
09-02-2012, 06:05 PM | #5 |
I am a Referee of life.
I would start with a stock clutch fan and a shroud.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
09-05-2012, 12:51 AM | #6 | |
20' Daredevil (Ret)
I would expect to run from 200 to 210 degrees at idle, maybe a bit more but that's about the max for what I'd consider ideal.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
09-05-2012, 05:20 AM | #7 |
I agree with Stocker about the radiator.
However anytime you are trying to put horsepower to the ground you want to get rid of parasitics on your engine so an electric fan setup is always the best option if you have the cash. |
09-04-2012, 09:14 PM | #8 |
I would stick a 18" clutch fan on it myself I would think that would pull alot more air in then what you have on it now.
09-05-2012, 06:35 AM | #9 |
Thanks for the input guys..! I have a dual 13.5" Flex-A-Lite 4600 cfm on the way... I will update..
09-05-2012, 09:04 AM | #10 |
2WD Jimmy
Get rid of that Flex fan. Get rid of it.
09-10-2012, 12:41 PM | #11 |
Electric Fans done the trick. Idling at 190 and all is well..! Thanks..
09-11-2012, 03:56 PM | #12 |
Have a part number on the fan and how about some pics thanks
Fuzzy |
09-14-2012, 12:08 AM | #13 |
, "FLX-298" in Summit. I will post pics later, I need to take some...
09-17-2012, 04:33 PM | #14 |
I can't seem to upload the pics from a mobile device and its the only access to the web at the moment. Will keep trying.
