Driver window just stopped
working on a 69 GMC c10 and now i need to learn about replacing the window crank mech as the gear/crank is not working, all the tips for parts and installation would be very much appreciated.
ffixit46 |
member #16
![]() Join Date: Dec 1999
Re: Driver window just stopped
heres a thread from the faq section. There are alot of good writeups in there. And welcome to the board.
http://67-72chevytrucks.com/vboard/s...d.php?t=157539
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
have you tried spraying the insides real good to get the 40years of petrified grease and grung loosened up to allow the crank to move freely
#4 | |
Posted via Mobile Device |
Old Skool Club
![]() Join Date: Jun 2001
If the window winder is floppy, then there is wear within the mechanism. If the handle and shaft are tight, then it probably just needs cleaned and lubed....meaning the guides and slides. If any of the guides/rollers are broken, you'll need to replace them.
But, they're not expensive and not hard to get to so you can replace them.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
welcome to the forum, lots of good info here as you now know
