700r4
Do I need a computer to run a 700r4 trans in my truck?
Re: 700r4
I'm pretty positive it depends on the year of the transmission, but more than likely no.
1985 Chevrolet K10 Custom Deluxe---SOLD 1997 Ram 2500 5.9 Cummins 1985 Chevrolet Camaro Z28 1987 Chevrolet K10 Silverado "The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257 |
Re: 700r4
Great question. Anyone have pain points they can share?
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
Re: 700r4
What about the converter? Is it the same as what I use for a turbo?
Re: 700r4
No computer is needed for a 700r and no the converter is not the same as the 350/400 turbo transmissions. It's the 4l60e that needs the computer. As for the pain points there not very strong if you have much more than a stock engine. I'm sure others will have their stories to add
Posted via Mobile Device |
#6 | |
Re: 700r4
Parts and more parts
Re: 700r4
You can run a 700 without a computer and a Lockup converter, I have one in my truck that has no Lockup. The valve body has to have some simple mods done to make it happen. However if you want a lockup, then there are kits from B&M and other companies that will let you do that.
Frank |
![]() Join Date: Jun 2011
Re: 700r4
I have one i bought a b&m lock up for summit you to lock up to get the most gas mileage easy to hook up.
Sisyphus was my mentor!
![]() Join Date: Sep 2002
Re: 700r4
No computer required. I love my 700r4. In our trucks it likes a 3.73+ gear. Had it since '98 & had it rebuilt 1x in that time. I use the Painless Wiring kit for it to run the lock up but there are cheaper solutions out there.
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
Re: 700r4
There is a way to make it lockup automatically in the transmission with no electronics required.
Re: 700r4
I want to know how 1972 Red Neck'
I've been running my 69 C10 350? 700r4, and 3.42 rear end with no pains with out lock up |
Re: 700r4
Heres what I've learned about running a 700R4 without a computer.
1) You need a 1992 or older 700R4. 2) Instal a Lockup Kit. 3) Instal a adjustable Vacuum switch and a Brake lever switch. 4) Instal a TV cable, and have all components adjusted properly. 5) Enjoy the hell out of Overdrive. |
Re: 700r4
A member in this thread mentioned He uses a 400TH I'm going start looking for one, to see how it works.
Just Curiuos. |
Re: 700r4
I have a 400TH in my BB 67 already. I was needing the info for a 41 chevy PU with a stock 350.It has a 3:73 gear in it. Thanks guys, I'll take what I need out of this thread. Johndawelder
#15 |
![]() Join Date: Apr 2012
Re: 700r4
Subd
#16 | |
Re: 700r4
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb ![]() |
#17 |
Re: 700r4
Cool, good information I will check that out.
#18 |
![]() Join Date: Jul 2009
Re: 700r4
I have a 700r4 out of a '92 (actually denoted as a 4L60...no "e"). I used the overdrive kit from Bowtie overdrives, TV cable & bracket for my quadraBOG, and I converted it from electronic speedo to mechanical speedo in the process. I also added a corvette servo kit to firm up the shifts and I love it! 3.42 gear and a 29" tall tire, it runs out like a champ.
#19 |
Re: 700r4
Nice. Gonna look into that
#20 |
Re: 700r4
Great information!
Matt Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784 My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924 ![]() My philosophy on tires is the same as cigarettes. "smoke them if you got them" HAPPILY DIVORCED! |
#21 |
Re: 700r4
Question, will the 700R4 fit in my 72 without any fitment issue. Will it clear trans tunnel ok?
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
#22 |
Re: 700r4
Has anyone used a 700r4 with the TV elimination kit? I see a few kits out now and might try one out on my 6 cylinder.
#23 |
It's Better With Nitro
Re: 700r4
I would not recommend a manual valve body just to eliminate the TV cable, if that's what you're leaning to. Adjusting the TV cable is simple and you can use the automatic transmission what it was designed for...as an automatic transmission.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
#24 |
Gearhead
Re: 700r4
I loved my 700R also, I used the B&M vac switch kit for lock up control and never had a single problem with it. I highly recommend getting the Bowtie Overdrives components for the TV cable, set it how they tell you and enjoy cruising at low RPM. You might also look into the 200R swap, it is easier from what I hear and gear ratios are better, the 1-2 gap on the 700R is a little extreme...
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 Last edited by 6772owner; 10-31-2012 at 11:01 AM. Reason: text |
#25 |
Re: 700r4
I have a 700r4 in my c10 as well, 327 V8 with a 3.08 rear and I'm getting almost 25mpg. I have the TCI lock up kit and the only major thing the transmission shop stated was proper adjustment of the detent cable or TV cable. Having the right brackets to attach it to your carb is a must!
-Rus |
