Old 09-05-2012, 09:14 AM   #1
Square_78
Square_78's Avatar
After disc conversion, same offset?
Hello
I have a clean 1970 GMC 2wd with 6 lug drums
I want to static drop as much as I can and buy wheels ASAP so I have a nice weekend driver. Most likely 20x8.5 and 22x10 wheels.
Eventually it will be bagged with disc brakes but I am on a TIGHT budget and its going to be a couple years before it all gets done. I would like to do wheels and static drop now, then next summer convert to discs/drop spindles, then bag it over the following winter. Having to convert the thing to discs was a BIG unforseen expense when I planned this whole project.
My question is, after I swap to disc brakes using a conversion kit, are my wheels still going to fit properly in regards to offset? Will the new disc conversion retain the same offset as the factory drums? I cant seem to find an answer and i DONT want to assume its going to be exactly the same. I need to know for sure before I spend the money on wheels.
Anyone have any info they can share?
Thanks in advance
Lonnie
Square_78 is offline   Reply With Quote
Old 09-05-2012, 09:33 AM   #2
LEX
LEX's Avatar
Re: After disc conversion, same offset?
Here's a thread with good info on the subject.
http://67-72chevytrucks.com/vboard/s...d.php?t=485760
LEX is offline   Reply With Quote
Old 09-05-2012, 09:44 PM   #3
Square_78
Square_78's Avatar
Cool thanks..
So apparently on my 1970, it will move the wheel out 3/4". It also varies according to spindle manufacturer. I guess Im going to have to wait until I do the brake conversion before I can buy wheels. Not what I wanted to hear, but thanks for the info.
Lonnie
