Old 09-07-2012, 03:53 AM   #1
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
truck camper
Could my 1/2 ton trailering special handle a truck camper? If so, how long and weight should I keep under for safety?
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 09-07-2012, 02:06 PM   #2
Desert1957
Desert1957's Avatar
Re: truck camper
I think even with the rear springs upgraded it may be too much. My concern is the 1/2 ton brake setup.
I just purchased a "Lance 850" truck camper for my 3/4 ton 83 , but it has a "Camper special" option. So it rated for 3231 lbs (sticker in glove box)
My 87 1/2 ton in my avatar wouldn't do it.
All parts I purchase seem to cross over to 1 ton , Here is a picture.
Camper weighs in at 3000 lbs fully loaded.
Another option is a camper that pops up like a 'Palamino"
And has to pull this...
Desert
Desert1957 is offline   Reply With Quote
Old 09-07-2012, 04:05 PM   #3
Squareforceone
Squareforceone's Avatar
Re: truck camper
Excuse my ignorance this is probably a stupid question but, what exactly holds a slide in camper in the truck bed? I've never know anyone with one and always wondered. Thanks
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 09-08-2012, 06:41 AM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: truck camper
If you look real close at the picture of the camper you will see about mirror mount high two triangles bolted to the bed. there are tiedowns from the camper to the truck there and in most if not all there are rear tie downs too
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 09-08-2012, 07:44 AM   #5
72freak
Rottenwood Garage Member
72freak's Avatar
Re: truck camper
They do make some very light weigh ones that may work.....but NO. Most 1/2 ton trucks wont work without some major upgrades. If you are going short distances and you upgrade your suspension i would say go for it.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 09-08-2012, 09:18 AM   #6
Desert1957
Desert1957's Avatar
Re: truck camper
Here is a pic of the mounting system that's most popular.
This system will not work with our trucks due to the fuel tanks covering up the frame mounting area, so in my case I had to go with a bed mount system.
Desert
Old 09-08-2012, 10:22 AM   #7
tucsonjwt
Re: truck camper
My 83 C20 had pieces of square tubing welded to the frame, with other perpendicular pieces of tubing welded to them, which I think created a place for the first picture tie downs to hook. However, the slide in truck campers I have driven do tend to create a top heavy sensation when driving, so that is the only thing I don't like about them.
tucsonjwt is offline   Reply With Quote
Old 09-08-2012, 05:46 PM   #8
Desert1957
Desert1957's Avatar
Re: truck camper
Yes, That setup is called a "Belly Bar" I just didn't like the way it looked with the camper off.
Old 09-07-2012, 04:30 PM   #9
Edahall
Re: truck camper
It won't be able to handle much camper in stock form but there are some things you can do to help it out (significantly).
1. Rear sway bar
2. Rear air bags
3. Wide rear tires 8-10 plies (285/75/16 or 305/70/16)
4. Exhaust brake
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 09-08-2012, 01:22 AM   #10
Desert1957
Desert1957's Avatar
Re: truck camper
1. Rear sway bar
2. Rear air bags
4. Exhaust brake
I agree those things will improve it but , You still have 1/2 ton, will small brakes and a thinner frame (more flexing) these camper put a lot of stress on a truck.
Desert
Old 09-08-2012, 02:20 PM   #11
Edahall
Re: truck camper
Desert
OK, I'll address those concerns.
The frame on a 73-87 1/2 ton truck and 3/4 ton truck are the same. Yes, 1/2 ton trucks flex more but that is due to lack of rear sway bars and tires with floppy side walls. Correct those issues and it'll be just as stiff as a 3/4 ton truck.
You're correct that a 1/2 ton truck has smaller brakes but you can more than compensate by installing an exhaust brake.
Old 09-08-2012, 05:44 PM   #12
Desert1957
Desert1957's Avatar
Re: truck camper
WRONG.......I hear this ALL the time , Its a reoccurring perception on this forum by many.
Not all 3/4 ton frames are the same . I have measured my 3/4 ton frame everywhere it can be measured . Same outside dimensions height and width BUT the frame is almost .0100 thicker than my 1/2 ton. That equates to almost 1/8 of an inch thicker. making it way stronger.
Added a "Hellwig" rear sway bar and "Rancho 9000XL" Shocks which takes out all the body roll, night and day difference
Yes the stamping of the frames are identical, even down to all the hole locations , but just don't make assumptions until you know all the facts needed.
Desert
Old 09-08-2012, 09:50 PM   #13
Edahall
Re: truck camper
WRONG.......I here this ALL the time , Its a reoccurring perception on this forum by many.
Desert
I guess we will have to agree to disagree here. I have measured my 1/2 ton and 3/4 ton frames and they are exactly the same thickness.
Old 09-08-2012, 02:10 PM   #14
79gmcc15
79gmcc15's Avatar
Re: truck camper
Thanks guys, as always awesome help! Kinda thought the same thing.
RIP ELJAY
Old 09-09-2012, 12:23 AM   #15
Re: truck camper
Not all campers are 3,000#. A 1/2t can haul a lighter camper. It's a truck,after all. The 10' camper I hauled on my '71 C/20 was very light (no bath). It barely set the truck down and I barely felt it on the truck. I'm sure a 1/2t could haul it just fine. Sure,some common sense upgrades would help.
