Compression Ratio
Guys, I am about to build a 408 stroker motor out of a stock LQ4 motor. In my experience of putting hotrod motors in EFI vehicles, there sometimes is a problem of making the computer(ECU,PCM) and the compression ratio work together and be a "happy couple". Would you knowledgable LS guys here on the board reccommend a compression ration to stay away from? \
I know a lot depends on what I expect out the motor and what I am going to do with the vehicle that the motor is going in so here is the basics. Its going in a SWB truck and I would like to achieve 450 RWHP. So that being said I am estimating that the crank HP needs to be in the 575 to 600HP range. Opinions please?? |
meowMEOWmeowMEOW
Re: Compression Ratio
Even with a built 4l80e, that seems like a high estimate for drivetrain loss.
I don't think the compression itself would be an issue....if you tune it with HP Tuners, the tuner should be able to setup things like VE tables to have a "happy engine". I'd think you'd have a bigger issue with stuff like knock sensors not liking huge cams. How high are you trying to go? I've seen motors up to around 11.5:1-12.1 being tuned just fine, provided that they have enough supporting gear (intake and head flow and injector and fuel system capacity)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
I have to agree with BR3W CITY, make sure you are supplying enough fuel, 60lb injectors for what you are doing sounds around right. If you have a good tuner all is well.
My 418 is 12.9-1 and I have run it on 91 octane. Made 511rwhp through a loose converter and glide. That was with very conservative timing, 20* total at WOT. Stood on it quite a bit on the dyno and showed 0* KR. Have also driven it around a few hundred miles with 0 kr. Keep in mind, I have a cam with a decent amount of duration, and my dynamic compression comes in at 8.7-1.
On E48 it made 546rwhp with 26* total timing. Didn't make anymore with 28* or 30*.. FYI, my 60lb injector on E48 are mid/high 60% duty cycle at 58psi fuel pressure. Posted via Mobile Device
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
