05-26-2003, 01:31 PM | #1 |
Brake booster replacement
How do you ID the Brake booster to buy the right replacement part?
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
05-26-2003, 11:13 PM | #2 |
Brake Booster
Don't know if this will help but I only know of two boosters...The first is the single diaphram type that is of a larger diameter and thinner from front to back and the second is the dual diaphram version that is thicker and, if memory serves me right, is a smaller diameter. I swapped a unit from a '72 'Burb into my '67 and it turned out to be the dual diaphram type. It also uses a short throw plunger which only protruded about a quarter inch into the master cylinder vs. a longer (1" or more) plunger for the single diaphram booster. I used a stock corvette master with the shallow piston whereas the single diaphram unit used a plunger that extended out far more by at least an inch or more. I know this still doesn't give you much to go on but it's all I know to tell you right now. Hope this helps. Trukman1
05-27-2003, 08:22 AM | #3 |
Here is some information that may help you.
http://www.brakeboosters.com/booster.htm In the picture, the top left is a Bendix and the bottom right is a Delco booster. Out of the 9 trucks that we have with power brakes, (8) are Bendix and (1) is Delco. Jim |
05-27-2003, 09:22 AM | #4 |
Running on empty
Which one is the most likely to be on a 3/4 ton truck?
_____________________________________________ Tim We have two rules here at the Rock. Rule #1: No writing on the walls. Rule#2: Obey all rules 70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi; 94 Bronco XLT 302, auto;worn out daily driver |
05-27-2003, 10:15 AM | #5 |
I don't remember which one might be for a 3/4 ton truck. They were usually the double diaphragm type. I have one that I can look at later today and post a pic if no one else does in the meantime.
Jim |
05-27-2003, 08:20 PM | #6 |
Here is a pic of a 3/4 ton Delco brake booster, front view.
Jim |
05-27-2003, 08:25 PM | #7 |
Here is a pic of the 3/4 ton booster side view. As can be noted it is thicker than a single diaphragm booster as it has two diaphragms in it. (The double diaphragm is approx. 6" thick and the single is approx 4" thick).
Jim |
05-27-2003, 10:14 PM | #8 |
Designated A-hole!
I didn't recognize it without any rust!:p
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
05-27-2003, 11:43 PM | #9 |
its all about the +6 inches
I sold my repair manual, so i can't referance it nor name the manufacturers, but I believe there were actually 2 brands of daul diafram boosters that were quite differant
05-28-2003, 08:34 AM | #10 |
Andy,
I think that you are right on this. I took a dual diaphragm off of a 69 3/4 ton that was smaller in diameter and we used it on my son-in-laws 56 Chevrolet. The problem is there are no names or numbers on the diaphragms. Jim |
