8 lug to 5/6 lug
my truck is a 3/4 ton thats static dropped. im having a very hard time finding wheels that are the correct offset, with, size. i lowered a 3/4ton because i wanted it to be unique rather than a 1/2 ton. since i cant find any wheels that i like(or fit), i was wondering if i can keep the 3/4 suspension but drill out the 8lug pattern to a 5 or 6 lug pattern. the only thing is, i dont know if a 5/6 lug pattern can fit over the center hub on a 3/4 ton axle. any help/opinions apreciated.
1979 GMC 3/4 ton camper special 454 (7/8in drop) UPDATE: CADDILAC 500 SWAP AND 4X4 SWAP ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=518625 1965 gmc 4x4 build : http://67-72chevytrucks.com/vboard/s...d.php?t=724972 |
Re: 8 lug to 5/6 lug
There are conversion drop spindles. You keep everything except the spindle and brakes. In the rear they make 5 lug hubs. $400 bucks.
Posted via Mobile Device |
dont convert it to 5 or 6. it was made a 3/4 ton so i say keep it that way you gotta be different
75 c30 silverado drw 454/th400hd d70 soon to have d60 up front 73 c20 custom deluxe sm465 14bff parts truck |
hope someone puts some input on this i have 3/4 that i want to lower and was wondering on lowering and what wheels and tires to run
yeah i dont want to buy drop spindles again. i already spent $400 on mine. the problem is the wheels that will fit and do look really nice are over $2000! so i just thought that maybe converting it to 5/6 lug would be cheeper but it doesnt look like its going to be.
67-72 parts collector,…
![]() Join Date: Nov 2002
Your gonna have to change spindles and the rearend at a minimum.
No redrilling will get it done. Spending more money is your only option. A donor truck might make things cheaper. Posted via Mobile Device
