05-26-2003, 05:07 PM | #1 |
Location: Bondurant, IA but in Worcester, MA for school
Wheel Bolt Pattern Question
I just wanted to make sure of this before I ordered new wheels for my 1970 Chevy C20 with 8 lug wheels. the bolt pattern is 8 on 6.5 right? THanks
HotROd
1970 Chevy C-20 350 V-8 Turbo 350 w/ shift kit Dana 60 w/ 4.10 gears AND Powr-Loc POSI New Additions: Summit Headers 135amp alternator Proform HEI Edelbrock 1406 600cfm carb Sunpro Tach Powr-Loc POSI Edelbrock Performer RPM Intake MSD 6A Ignition Box AIM: HotRod929 Visit My Site: http://1970chevy.netfirms.com/ |
05-26-2003, 05:27 PM | #2 |
its all about the +6 inches
I think so...they are pretty much all the same, ford, dodge, GM...it's the center 'hub hole' that matters.
05-26-2003, 08:40 PM | #3 |
yeah, I have Dodge wheels on my 3/4 ton but I hear the Dodge cannot use Chevy wheels......
57 suburban(sitting in the driveway), 2 69 C20 longbeds (sitting in the field ) and a 2003 8.1 Suburban Endeavor to persevere. "All of a sudden, I'm the old timer!" Some old timer on American Pickers. |
05-26-2003, 09:05 PM | #4 |
Glowing since 1978
The wheels were originally designed as hub piloted wheels I believe. They use the center hole to hub contact to maintain the wheel centered. Good part about that is you lift up the wheel and once it goes over the center hub you don't have to hold it up while trying to thread on your lug nuts. You can use other manufactures wheel like Dodge or Ford but the center hole diameter is to large to correctly center the wheel. You then have to use lug nuts designed for stud piloted wheel. You know the type. The chamfered end of the lug nut mates with a corresponding chamfer on the stud hole in the wheel. The hub piloted lug nuts are typically flat on the face against the wheel unless you use a clamping plate which was common in all newer GM applications. For additional information that you may find valuable follow this link and download the PDF file. Have fun learning more than you ever wanted to know about hub piloted and stud piloted wheels. http://www.accuridecorp.com/products...t_catalog.html
Don
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper Last edited by ddsmith; 05-26-2003 at 09:08 PM. |
