09-09-2012, 07:54 PM | #1 |
5000 lb Air Lift Helper Bags on Lowered Flip Kit Truck
Havent seen to many lowered c10's with a flip kit and bag over axle so i figured i'd share. the Air Lift 5000 kit was for a f-450, it was band new and got it for less than hajf price. the only things i did was cut the bed rib bracing so i could keep the bracket up high as i could, drill the upper bracket holes and and modded 2" spacers.
09-27-2012, 07:50 PM | #2 |
Re: 5000 lb Air Lift Helper Bags on Lowered Flip Kit Truck
BEFORE BAGS AIRED UP
AFTER BAGS AIRED UP |
09-27-2012, 09:46 PM | #3 |
Wow. It can be done! I've been considering this on my 77 burb. Only thing I have been worrying about is not wanting to cut into the rear bed, I did not want to do any more cutting than a regular c notch. I worried that I would not have enough space from the axle to the frame to sandwich an air bag in there. But this looks like I might just have enough room.
Posted via Mobile Device |
09-27-2012, 10:59 PM | #4 |
my frame isnt notched and im sitting on a flip kit and 2 inch lowering shackles. i just cut the rib bracing under the bed, only one of them where the bag bracket is, and theres no holes in the bed. 350 lbs on a lowered tail gate could sit the frame on the axle but no more! these added 5000lbs of extra loading capacity!
09-27-2012, 11:01 PM | #5 |
btw, the pressure of the bags are on the axle not the springs. this allows the no pressure on the u bolts of the axle/springs
06-03-2013, 12:08 PM | #6 |
Old thread but just what i was thinking.Anybody more who have airbags
to support the rear end when loaded ? Have flipkit / DJM shocks and removed rear axle bump stop and is there any airbag kit that just will bolt on ? Have not a c notch on my truck. More pictures would be awesome
Chevrolet Cheyenne K2500HD 1992.350tbi.4L80E. GMC Sierra Custom C1500 1983. Oldsmobile Dynamic 88 -65. Volvo V70 -02 and BMW 523i T -99. Harley FXDF -08 and Harley FXDB -10. Honda Dirtbike Dominator -97 and a couple of tractors. |
06-30-2013, 12:00 PM | #7 |
How do you air them up? Do you just use an air compressor or do you have a small tank and small compressor like a slammed air bag truck? Been considering something like this for my truck..
Where is the best/ cheapest place to buy a couple bags? Posted via Mobile Device |
06-30-2013, 01:11 PM | #8 |
My 74 was set-up w/a home-made air-over-leaf set-up. I used 2 Schrader valves mounted in the bed when I needed the extra capacity.
06-30-2013, 09:05 PM | #9 | |
07-01-2013, 01:30 AM | #10 | |
11-21-2013, 12:25 AM | #11 | |
Chevrolet Cheyenne K2500HD 1992.350tbi.4L80E. GMC Sierra Custom C1500 1983. Oldsmobile Dynamic 88 -65. Volvo V70 -02 and BMW 523i T -99. Harley FXDF -08 and Harley FXDB -10. Honda Dirtbike Dominator -97 and a couple of tractors. Last edited by Swed-Chevy; 11-21-2013 at 12:31 AM. |
11-21-2013, 09:46 AM | #12 |
No I have not picked up the kit yet. I had some noise in the front end, and had to completely rebuild it. The bushings were worn, ball joints etc. I am looking to buy my wife a new car after the first of the year, then I can drive her car every day. I'm hoping that will allow me to just do a compete frame off resto on the truck. I'd like to fab a 5 link system with the bags and add bags up front for the ride quality and towing capabilities. We will see what the new year brings financially as to wether I can afford this or not. Hopes and dreams!! Haha
03-23-2015, 11:13 AM | #13 |
updates??? im really liking this set-up would you peeps recomend this or aol? also will i get more drop on a k5?
03-23-2015, 06:16 PM | #14 |
Only thing this won't work on trucks with a c-notch unless a custom upper bracket is installed. I had to install the bags opposite of each other because of the shock getting in the way. I'm going to have to take some pics when I have time.
03-23-2015, 06:42 PM | #15 | |
Badchevy is correct, this wont work with a c-notch without a custom upper mount. |
03-23-2015, 10:01 PM | #16 |
awesome! thanks for the input/feedback how many leaves are you running with this set-up? do you think id have any problems running my 22" rims with 265/35/22 tires?
03-23-2015, 10:53 PM | #17 |
Couldn't stand it, had to go check. Running 3 leaves and I can get my fingers between the wheel/tires and the bags.
03-24-2015, 04:34 PM | #18 |
driving is in my blood
Why would anyone want 5000lbs of extra load capacity on a 1/2ton truck?
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
03-24-2015, 05:18 PM | #19 |
You wouldn't but the smallest diameter dbl convoluted is rated @ ~2500lbs or 5k w/2 of them. The rating is also @ mfr recommended pressure (~100psi) which wouldn't be required either. Mine never exceeded about 40psi.
03-24-2015, 06:04 PM | #20 |
03-25-2015, 09:55 AM | #21 |
^^^ exactly!!! thanks for the info! so i can run 4 leafs with out the overload spring yes? looking to do this as soon as i get the c10 to my ranch/workspace.
03-25-2015, 03:01 PM | #22 |
03-25-2015, 04:42 PM | #23 |
I ask because 5000lbs sitting the bed of the truck isn't going to work out well for the frame or axles. My truck is lowered and only has 1000lbs of helper bags and it tows and hauls anything I can put in it so far. The more weight, the higher the bag pressure, which equals out to a softer ride the more weight I have. Love it.
03-25-2015, 07:43 PM | #24 | |
