Old 09-10-2012, 04:11 PM   #1
jocko
jocko's Avatar
long vs short wp
I realize this is an engine-specific question, but asking specifically because I'm looking at a K10 with a replacement goodwrench engine...
Since it's a later engine, am assuming it has a long water pump, whereas our trucks had the short pump through 72 (though cars transitioned in 69 I've learned on here from other members).
Here's the question - since this truck would be a long-term plan of rebuild and potentially shoehorn in a 700R4 after bumping the motor forward a few inches - can a short water pump be fitted onto an engine that originally came with a long pump?
Same relative question for crank balancer and pulley forward fit to a newer engine...
Unfortunately, I don't know anything about how new that engine is other than it is a non-vortec goodwrench 350.
Thanks in advance.
Old 09-10-2012, 04:38 PM   #2
Wrenchbender Ret
Re: long vs short wp
The Goodwrench engine is a replacement engine. It is supplied as a "long block". All the brackets & pulleys are used from the old engine. Either the long pump or short one will work on it. They also have holes for the dipstick tube on both sides.
Wrenchbender Ret is offline   Reply With Quote
Old 09-10-2012, 05:03 PM   #3
SS Tim
SS Tim's Avatar
X2
SS Tim is offline   Reply With Quote
Old 09-10-2012, 08:25 PM   #4
jocko
jocko's Avatar
thank you gents! that what I was hoping to hear - and I wasn't sure if the goodwrench was available carb-to-pan with all the pulleys/accessories, etc - glad to hear it is just the long block. Thats good news.
Old 09-10-2012, 08:50 PM   #5
WIDESIDE72
WIDESIDE72's Avatar
If equipped with a lwp it probably also has an 8" balancer, which is too large for the SWP set up. The larger balancer interferes with the short water pump.You will need to swap it for a 6- 3/4". (I believe that is the diameter of the smaller balancer.)
WIDESIDE72 is offline   Reply With Quote
Old 09-10-2012, 10:16 PM   #6
doubleb's69
doubleb's69's Avatar
I know you already have some answers but I have a 260 horsepower Goodwrench crate engine in mine with the short pump and a 4 core radiator and everything fits great.
Bud
doubleb's69 is offline   Reply With Quote
Old 09-10-2012, 10:28 PM   #7
jocko
jocko's Avatar
great - thanks doubleb and wideside, appreciate the info.
Old 09-21-2012, 01:01 AM   #8
nra4life
Jocko, Either length water pump can be used on your engine, but ALL the brackets are DIFFERENT!! Unless you have access to COMPLETE sets of brackets, you had better stay with the water pump and brackets you already own. Complete sets of brackets are becoming hard to find, especially for the short pump. Roy
nra4life is offline   Reply With Quote
Old 09-21-2012, 02:56 AM   #9
stsalvage
Scrapper 1
stsalvage's Avatar
I have another question why in the hell would you move the motor forward.I've put 3 700R4 in and never touched where the motor sits if its a drop in Motor From GM and its the 290 HP crate motor.Most of the time you cut down the drive shaft and have it rewelded. its easyer to shorten a drive shaft them to make it longer
stsalvage is offline   Reply With Quote
Old 09-21-2012, 03:29 AM   #10
SS Tim
SS Tim's Avatar
By moving the engine forward to the 4x2 V8 position and depending on exactly how you mate it up, the transfer case can remain in the stock location. Still chasing down the specifics for jocko.
Old 09-21-2012, 07:09 PM   #11
WIDESIDE72
WIDESIDE72's Avatar
True in a 2wd set up, but in a 4x4 it is a way to avoid cutting front and rear driveshafts. Notice the original inquiry mentions "K10"...I first thought the same thing, til I noticed the "K10".
Old 09-21-2012, 07:22 PM   #12
jocko
jocko's Avatar
Tim & Wideside hit the nail on the head. It's a 4x4 thing - not as simple to put a 700R4 in a truck with the T-Case, etc. There are a few threads on here about this swap if you google em.
Old 09-21-2012, 07:40 PM   #13
airdale94
airdale94's Avatar
OT but jocko did you have that truck (avatar) on E-Bay awhile back?
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
