73-87 Xmember
hey guys need a little help here i was wondering if anybody here knows if a 73-87 C30 front stock Xmember is the same or made of the same thickness metal as of a 73-87 c10 i hear some people before said that the lower control arms are different but im not sure on the Xmember any info will be greatly apreciated thanks
nOtHiNg LiKe ThE gOoD oLe ChEvYs.... ![]() |
Re: 73-87 Xmember
Bump.... so nobody knows? i thought i would get more responses here than any other forum since it has more members but i guess i was wrong...
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 73-87 Xmember
I believe the crossmember is the same.
The C20/C30 lower a-arm has a larger ball joint hole compared to the C10 lower a-arm.
Re: 73-87 Xmember
ok cool thanks for the response bro..... so the mounting bolts on xmember is all the same on c10 and c30?
#5 | |
Re: 73-87 Xmember
I have never done this myself. But alot of the 1/2-ton crew cab guys have. Any reason you want to remove the crossmember? I would just swap everything from the a-arms out. (and the steering) What is your plan here? What are you trying to accomplish?
Re: 73-87 Xmember
i currently have a sectioned c10 Xmember and i want to put it on my C30 dually all im gonna swap is the xmember im gonna use the same lower and upper arms but i hate to take it all apart and find out is different and it wont fit so i thought i ask some of you guys and see if get some info i appreciate your input bro.
Slots go on anything!
Re: 73-87 Xmember
I am pretty sure the crossmember Scoti put in his dually was a C10 crossmember. It bolted right in for the most part. There are a few holes you will have to drill from the sectioning process.
1974 Jimmy- 5.3/4L80e/NP241 |
#8 | |
Re: 73-87 Xmember
Member SCOTI is doing that exact swap now. (I believe his is already installed)
Re: 73-87 Xmember
Sweet! thank you guys..
