09-13-2012, 07:00 PM | #1 |
Modified shift linkage -- does it look right?
If you've followed my build you know that I went with a TH200-4R overdrive while the original TH400 is saved away in storage. Physically, they're pretty close and it dropped right in.
Today I went to hook up the shift linkage, and it appears that the 200 has the linkage a little forward and inboard of where the 400 has it. In order to make it work, I flipped around the frame bracket and used spacers to move it inward about an inch. I won't be able to test it with the column linkage until the cab is back on, but it seems to work by hand, even though it's not lined up perfectly. Below is a photo. I'm wondering if anyone has run into this before and come up with a different or better solution, or if anyone can spot an obvious issue with how I solved it. Thanks, Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
09-15-2012, 12:41 PM | #2 |
the boat guy
Re: Modified shift linkage -- does it look right?
I used the car style linkage on my 4l60e after I got tired of trying to get all of that stuff to work. I had to make my trucks shifter rod a little longer but works great.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
09-15-2012, 02:54 PM | #3 |
I just install a TH200-4R in my truck as well, I just bought a simple shifter kit, I think it was $40.00.
Here are some pictures. Trimmed to fit perfect Here is a link to my Tranny install photo album, I have about 100 images of the install, with some good TY setup pictures & some pan dropped plunger images. TRANNY INSTALL PHOTO ALBUM Hope this helps. Scott
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi, My 68-SWB Photo Build Thread All my Google Albums |
09-15-2012, 03:07 PM | #4 |
Moderator
x2 on the Kugel Komponents shift linkage kit. I used it on my old truck with a 350/700R4. It can be dialed in no matter what combo you are running.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
09-15-2012, 05:07 PM | #5 |
the boat guy
Agreed. My rod needed the factory Z so I just lenthend mine. Hard to beat $40.
