Junior Member
Anyone running a one pice drive shaft?
I know there is a limit on length so I am not sure it will work. I have changed all my 67-72 trucks to a one piece with no probs.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 09-14-2012 at 07:03 PM. Reason: spelling |
Re: Anyone running a one pice drive shaft?
I'm using a one piece driveshaft with a spline slider that was originally used with a t-400 that had a bolted on yoke-plate.
I'm using it with a 700r4 that has a sliding (into the trans) yoke. To keep the driveshaft's slider from retracting too far, I put a valve spring in the slider. The driveshaft works good and without vibration.... It should be basically the same length as a longbed pickup....If you are concerned about the unsupported weight, have it made from aluminum! |
Junior Member
If it is the same length as a LWB I am ok with changing it to a one piece. I ran a one piece in my LWB 69 with no issues. I just thought the burb driveshaft may be longer. I think the max lenth they would make is 72".
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
![]() Join Date: Apr 2005
Same length, but if you are going to bag it, I wouldn't go with a 1 piece.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Hmmm... Ida thought that a one piece shaft, being longer, would present less u-joint angle variance over a given vertical travel distance..... I'm interested to know why the two piece is better for a bagged application....( I'm always lookin to learn!)
i put back the two piece drive shaft and it was cut to fit a slip yoke neaar the rearend. it works great for me just make sure you cut it to the right length because it will blow out your pinion bearing.
1972 Chevy Burb. C20 bagged up |
