Help - new guy with post accident leak
Hi Everyone,
So, we were taking our second voyage in our "new" 69 C30 when someone was unable to stop the truck and ended up in a creekbed, sideways with a ton of grapes strapped on the back of the truck. We finally got it pulled out, but it wouldn't start. The tow truck guy said he thought it had vapor lock as it would not turn over and the engine seemed to be almost in gear when attempting to start, rocking in its mounts. This was yesterday. Today I went out and found it turned over so got it started. When I did, lots of smoke came out of the exhaust. Also, when I opened the hood, there was a leak coming from the front of the engine. It seemed to be oil, but I was not sure. I checked the oil level and it seems quite high. As I just got the truck in the last month, I haven't really gone through the whole thing. Mainly we cleaned it up a bit and slapped some new tires on it. Not too sure about the brakes at this point, but this significant leak has me worried. BTW - 350 w a 4 speed. Thanks for any help/advice you can all provide. Got some great help on my carb. issue a couple of weeks back. |
I am a Referee of life.
Re: Help - new guy with post accident leak
Sounds like something overfilled the crankcase.Don't run it.It may be water or coolant,neither are good lubricants.You may have gotten water from the creek in it or it may be fuel(another poor lubricant).If the crankcase is full of water you could have a bad head gasket,a cracked block or just water from the creek.You should be able to tell if it's fuel by pulling the dipstick and smelling it.Let us know what you find.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#3 | |
So - guessing I should drain the oil as a starting point. Recommendations on oil weight? Not sure if is exactly smells like fuel right now as everything kind of smells like oil and gas. Thanks Brent |
20' Daredevil (Ret)
![]() Join Date: May 2003
It wasn't vapor lock, that's when the fuel vaporizes and the starter will crank the engine, but the engine won't start.
You probably meant hydro-lock, which is liquid in one or more cylinders and the engine won't crank over. If the oil is over-filled, that can cause a leak -- especially if the extra liquid is thinner than oil, such as water or fuel. You say it's not water, so -- does it smell like gasoline? You need to know if you're dealing with a water leak, an oil leak, or a fuel leak. And if the oil is overfilled, what is mixed in with it? And where did it come from? Yes, drain the oil, and try to figure out what's in it. I'd replace it with straight 30W or with 10W-30.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#5 | |
I suspect that it is fuel in the oil. The leaking seemed to be oily but thin. Also- I suspect it is coming out of the timing shaft area and getting sprayed around a bit. Hoping that the problem will resolve with proper fill levels and correct lubricant. Any thoughts on this are appreciated. AFA the brakes - I was told by the PO that the rears had been rebuilt recently. I think the problem was the guy driving the truck is used to modern power brakes and probably put his foot to the floor instead of pumping them. Also, he may have been going a bit fast for the load. I had driven the truck with a couple of tons of rock on the back 2 days earlier and noticed that going downhill with a load would be best in low gear, taking it very easy so I could stop. AFA was the truck on its side - it was pretty dang close. There was a tree holding it up by one of the bins of fruit that kept it from rolling. I think it was at about a 75 degree angle on its side. Very exciting for my buddy driving it, who was hanging in mid-air by a lap belt. |
the boat guy
Timing cover is behind and lower than the water pump and can leak oil.
Posted via Mobile Device |
Sounds like your trucks needs some basic service. When you had the issue with carb. did you ever check the oil for contamination? http://67-72chevytrucks.com/vboard/s...d.php?t=541348
When the wheels were changed did you check the brake system? Anytime you get a "new" vehicle it should be gone through to set a baseline and identify needed maintance items. This is especially true on vehicles that have been sitting or seem to be at the end of their service life. If you don't have the manuals (both factory chassis service and chassis overhaul), think about getting reprints or a CD as they will be helpful. At this point it sounds like there wasn't much damaged or anyone hurt. Do everyone a favor and fix what "needs" to be fixed and plan out the items that should be fixed.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Old Skool Club
![]() Join Date: Jun 2001
If you have a Q-Jet, they're prone to leakage and it will pool in the intake and leak past the valves. It'll wash the oil off of the cylinders and collect in the crankcase. Not good.
Not saying this is what you have, but just making a comment. Does your oil smell like gasoline?
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#9 | ||
"I ain't nobody, dork."
When you say "sideways" in the creek... do you mean the truck rolled over onto it's side? If so... oil very well coul dhave got into the upper part of the cylinder causing a bit more comression, and a crapload of white smoke when it is restarted.
Gary
It's probably fuel in the oil judging by the 75* angle comment.Drain and refill.The seal on the timing cover probably leaked when it overfilled.The brakes should not need to be pumped.Something is wrong.Check fluid levels and check inside of all wheels/hubs for fluid.If you don't find fluid check the drums/shoes,then master Cylinder.Don't rely on the PO for info.I've seen a "Bunch" of "spray can" Rebuilds on engines.Clean and paint and it's rebuilt?Judge this 40 year old vehicle by the old sayin',"Believe only what you see and be cautious about that."
![]() Join Date: Oct 2011
I'm glad you dont live by me. Hate to get run over by that pos.
#12 | ||
Catchy title goes here..
![]() Join Date: Mar 2002
terry b
perhaps you should review the site rules posted globally Quote:
Tags |
leaking oil |
