Old 09-16-2012, 03:44 AM   #1
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Need a tire size suggestion.
So the front tires on my 66 are currently 235/60/15, on mickey thomspon 15x8 wheels. That was what the po put on....my question is, what would you recommend switching to? The 235/60/15 is a little wide for the front, although it does fit just fine, I'm not sure if that much width is needed. The other issue is the cost of the tires, while not the most expensive, they seem to be a much less common size tire on 15. Any suggestions?
Fwiw, this is the front tires ONLY, so don't worry about the speedo being off...since this thing has always had different wheels and tires on it, I have no idea if the size is what it "should" be.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-16-2012, 09:48 AM   #2
b454rat
Re: Need a tire size suggestion.
Is the truck lowered? If it's stock I've seen a 31" tire on the front. That tire is real small fora full size truck, have the same size on the front of my car. Maybe a 235/70?
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 09-16-2012, 10:37 AM   #3
SCOTI
SCOTI's Avatar
Do you plan to utilize the current 8" wheel? If so the 235mm width is the minimum I'd do. Swapping to a narrower 7" wheel you could do a 215 or 225mm width tire in a 70 series or even taller 75 series height.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-16-2012, 11:00 AM   #4
b454rat
Any size tire will fit on an 8" wheel. I had an 87 that had the factory 8s and had 225/75s on it. They fit, but didn't look the greatest.
I saw after the fact that the truck is lowered. If you want to keep a fat tire (which a lowered truck should have IMO) a 255 or 275/60 would look good I think. If not, then the 235 I mentioned earlier or a 255 would work too.
Old 09-16-2012, 12:35 PM   #5
SCOTI
SCOTI's Avatar
Originally Posted by b454rat View Post
Any size tire will fit on an 8" wheel. I had an 87 that had the factory 8s and had 225/75s on it. They fit, but didn't look the greatest. I saw after the fact that the truck is lowered. If you want to keep a fat tire (which a lowered truck should have IMO) a 255 or 275/60 would look good I think. If not, then the 235 I mentioned earlier or a 255 would work too.
Agreed.... Any size can 'fit'.
I just don't recommend a narrower tire on an 8" wheel because it looks stretched vs what's typically utilized on the rear. I'm fine w/a 225/75 on an 8" wheel if a 275/60 is used on a 10" wheel as it keeps the sidewall proportions (stretch) symmetrical.
225's on an 8" wheel in front & 275's (or greater) on an 8" wheel in the back is a no-go for me.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-16-2012, 01:36 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The truck is roughly 4" dropped in the front, and I DO plan to keep the 8" wide wheel. The tire looks fine in the wheel well, maybe a little small but not much. I'll take a look at some "bigger" tires, i just don't want to run my inner fender well at all.
Scoti, did you mean a 255/60 or a 255/75?
Old 09-16-2012, 03:16 PM   #7
SCOTI
SCOTI's Avatar
255-60 would be slightly taller vs the 235-60 but a tad wider as well.
I've never heard of a 255-75 series tire in a 15" diameter.
If you want a narrower front tire that offers a bit more height, the 225-70 is a good size (235-60 = 26.1" OD; 225-70 = 27.4" OD).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-16-2012, 04:13 PM   #8
Malo83
Cruzzzn' Vet
Malo83's Avatar
I'm running a 245-60 on a 15x9" rim on the front of my Silverado with a 4" drop on the front
Malo83 is offline   Reply With Quote
Old 09-17-2012, 02:25 AM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I've found both 235/70 and 225/70's for the same price, both rated for light trucks (not really sure about running pass car tires on this thing w/ a v8)
I'd say those are prob my best bet for the price and availability, as well as the rating right now.
Old 09-17-2012, 08:51 AM   #10
SCOTI
SCOTI's Avatar
I've found both 235/70 and 225/70's for the same price, both rated for light trucks (not really sure about running pass car tires on this thing w/ a v8)I'd say those are prob my best bet for the price and availability, as well as the rating right now.
No different than a pass car of similar size w/a V8. Where it matters is when the vehicle has or pulls extra weight around.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-17-2012, 12:26 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I honestly didn't know that. I always thought there was a "reason" but I guess if my drag radials hold up fine with a load in the bed (long story), then a car tire would be fine up front haha.
