09-16-2012, 02:05 PM | #1 |
72 BB C30 Super LongHorn
1973 1974 1975 tach dash
1973 1974 1975 TACH DASH
Would like info on these. My 1973 & 1975 trucks do not have them installed from the factory. However, I have 2 Tach Dash panels. What are the differences? On the bulkhead wiring connector that plugs into the rear of the dash panels : Is the wiring loom the same across all of the models, with the printed circuit being the difference? Discussion please!
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS |
09-16-2012, 02:12 PM | #2 |
Re: 1973 1974 1975 tach dash
do you have an amp or voltage gauge in truck
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
09-16-2012, 02:14 PM | #3 |
The tach dash panels that I will be using are AMP gauge panels.
I am seeking answers for my future installation as well as providing a thread here for relative information.
09-16-2012, 05:12 PM | #4 | |
this may help http://67-72chevytrucks.com/vboard/s...ght=insulation
09-16-2012, 03:46 PM | #5 |
Some have machanical oil pressure and some have electronic. The ones I have swapped all had different pin locations on the plug/circut board.
You guys ever see one of these before? |
09-16-2012, 03:51 PM | #6 |
Yes, there is someone on the site who has done Camaro Gauge swaps.
Insidious I think... Yours has the earlier gauges and his has the later ones...
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 09-16-2012 at 04:53 PM. Reason: info add |
09-16-2012, 07:08 PM | #7 | |
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
09-16-2012, 04:13 PM | #8 |
Oh cool. here I thought I was original. LoL
09-16-2012, 05:40 PM | #9 |
That's helpful for me, Yes.
More suggestions from this site please! Posted via Mobile Device
09-16-2012, 11:04 PM | #10 |
My font matches better, speedo goes to 150 and lines up and fits perfectly. The lighting does not bleed through at all and most importantly, ALL the needles are a perfect match.
It's a little dusty cuz I did this about 8 years ago. |
09-16-2012, 11:29 PM | #11 |
Both are nice looking swaps.
So on the 73 -75 dashes, factory stuff, what else is known regarding installing these, fixes, etc etc?
09-17-2012, 12:09 AM | #12 | |
Have fun and keep smiling. |
09-17-2012, 01:00 AM | #13 | |
09-17-2012, 01:42 AM | #14 |
when was the first year issue of the speedo/tach having the blue line printed on the face of each gauge?
Amps to Volts gauge?
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 09-17-2012 at 01:50 AM. |
09-17-2012, 08:02 AM | #15 |
Not sure what year was first but mine came out of a 76 and has the blue line
09-17-2012, 06:21 AM | #16 |
I think this cluster started life as a 1981 or 82 C10 Chevrolet factory tach cluster, IIRC. I added 1971 Camaro Z28 150mph speedo (standard camaro is 130mph) and base 71 camaro 7000rpm tach (I think the Z28 had a 8000rpm tach)
I replaced the guage pointers on the truck guages with those off the camaro guages. (except for the fuel guage I never got that one changed)They are very easy to swap and makes it look factory. Camaro tach/speedo are very close to the same size as the ones I replaced and were an easy swap/. [IMG][/IMG] [IMG][/IMG] Last edited by wraprail; 09-17-2012 at 06:30 AM. |
09-17-2012, 09:31 AM | #17 |
Slots go on anything!
'76 is the first year for the voltage gauge. According to the '74 electrical diagram, the main plug at the cluster is the same for tach and non tach applications. Of course, you will have to run the 3 wires to the tach, but they are imprinted on the tach itself. Makes it easy. To my understanding, 73-75 should be the same, having an amp gauge and mechanical oil pressure. Not sure about the font on the speedo; I would swap in the original speedo from the truck you are swapping to anyhow. The rest of the gauges are pretty much the same.
1974 Jimmy- 5.3/4L80e/NP241 |
09-19-2012, 08:45 PM | #18 |
78K & 79C Jimmys
not sure about the "early" years but my 78
when i went from idiots to gauge n tach there were a few wires to move the gas sender and power + and - of course cluster plug is 79
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
09-23-2012, 12:52 AM | #19 |
Nice display of your harness.
Thank for posting that. Now I have something to compare with. Posted via Mobile Device
09-23-2012, 09:09 AM | #20 |
Great info! |
09-26-2012, 12:42 AM | #21 |
78K & 79C Jimmys
Great hope it works
09-26-2012, 01:52 AM | #22 |
Just tryin to establish what each year represents.
Has anyone to offer differences between these years : 73 74 75 ? The wiring loom bulkhead is a good start.
09-26-2012, 07:06 AM | #23 |
you really should buy a schematic
09-26-2012, 01:08 PM | #24 |
this would be nice to get...even comes with complete wiring harness
http://www.ebay.com/itm/1975-chevy-g...sories&vxp=mtr
