blazer side panels
Were the rear interior side panels an option or did all blazers have them? I have a '72 with them missing but when I looked closer , I don't see holes to mount all the mounting brackets. I parted out a few blazers yesterday and they all seemd to have the mounting brackets in them. I saved a few brackets, but my blazer doesn't have the holes to mount them to.
Re: blazer side panels
They were not on al Blazers. I believe CST's came with them. Base models did not.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
The original bracket screws were self tappers probably so the assemblers didn't drill through inner panel and hit the quarter panel. The angle pieces can be fitted to the floor and ends once the top rail has been mounted and the panels test fit. You can then install the panels and using a long thin marking tool that will go through the screw holes for the standoff brackets ( I used the wooden end of a small artist's brush dipped in paint), mark the center of the standoff brackets. Remove the panels, screw on standoff brackets, and do final install of panels.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
These will probably be the last items I add due to the cost. I just got the rest of the brackets though.
Posted via Mobile Device |
