Old 09-20-2012, 10:58 PM   #1
cmyc5575
Question about drop shocks with flip kit?
I am going to spend the money to buy a full belltech system. But the thing with this kit comes drops shocks. But my question is that if I use the drop shocks for the back do I have to buy shock extenders?
cmyc5575 is offline   Reply With Quote
Old 09-20-2012, 11:35 PM   #2
J Knight
J Knight's Avatar
Re: Question about drop shocks with flip kit?
No, you won't need shock extenders with drop shocks.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 09-20-2012, 11:36 PM   #3
cmyc5575
Thank you.
Old 09-22-2012, 01:34 AM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
Would rather run shock extenders though. Sets the rear shock angle better
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 09-22-2012, 05:02 AM   #5
87squarebody
87squarebody's Avatar
I would run shock extenders like insidious86 says also you have to grind the lower shock nut on driver side to get it on.It sits right on top of the plate were your u bolts run through.
87squarebody is offline   Reply With Quote
Old 09-22-2012, 05:02 PM   #6
cmyc5575
Would you or any one else happen to have a picture of this where this was done? For referrence.
Old 09-22-2012, 07:10 PM   #7
INSIDIOUS '86
Mine run with two and are fine. You can also weld them which is my suggestion
Old 09-22-2012, 07:55 PM   #8
87squarebody
Here is a pic of what i ran into.Another thing is running 15" rallies you will have to grind the lower control arm.This is a 5/6 bell tech drop.
Old 09-22-2012, 08:02 PM   #9
cmyc5575
ok well thats what im going with is a 4.5/6 bell tech kit. But what part is needing or suggested to be welded to the axle?
Old 09-22-2012, 08:03 PM   #10
cmyc5575
also I dont if my wheels are considered to be rallies but the are deffinately 15's
Old 09-23-2012, 05:03 PM   #11
INSIDIOUS '86
Would suggest welding the shock extenders. But mine are held in with two bolts and hold fine. And I beet the crap out of my truck daily
Old 09-23-2012, 05:34 PM   #12
bigblock73
yeller
bigblock73's Avatar
I have run drop shocks on all my lowered squares, never had an issue. Plus, the shocks bolt right up, no need to deal with the hassle of extenders.
bigblock73 is offline   Reply With Quote
Old 09-25-2012, 06:19 PM   #13
cmyc5575
Thats what I was thinking about instead of the hassle.
