Old 09-22-2012, 05:05 AM   #1
mcmlxix
Collector of Projects
mcmlxix's Avatar
What over the counter EFI fuel filter?
I am running a returnless style system and I'm looking for a simple canister style fuel filter for EFI. My fuel pressure regulator is in my factory fuel pump module, so I just need a low pressure dop filter. I plan on using some 3/8 fuel line in 5 foot sections from the local parts store that has ends on it already and put the filter in line at one of the breaks in the fuel line...
OE style... but should have a female 3/8 on each end....
Plan B is a nice Aeromotive canister filter but is big bucks.... # 12317
Rich
1972 K5 Blazer CST Click HERE
Old 09-22-2012, 11:50 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: What over the counter EFI fuel filter?
Wait, what regulator on the pump? Which style pump are you using that has a regulator built in?
If your running returnless, the vette regulator would also be the filter, unless you'd want more protection than that.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-22-2012, 05:20 PM   #3
mcmlxix
mcmlxix's Avatar
the fuel pump is from a 2005 Denali and has the regulator built in... GM# 19167467 or FG0340
Rich
Old 09-22-2012, 06:02 PM   #4
clinebarger
The fuel filter is also built into the module.
clinebarger is offline   Reply With Quote
Old 09-22-2012, 11:19 PM   #5
ls1nova71
ls1nova71's Avatar
If you want to put a filter in line, you could use an AC Delco GF481 (or the Wix equivalent 33481), but you won't be able to use the double flare that comes on the metal line, fuel injection filters use O ring fittings. There are filters that use double flare, but generally are not rated for the high pressure of a MPFI system, and would probably blow apart internally, not what you want to happen.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
