Old 09-22-2012, 03:44 PM   #1
1972BackInBlackC10
1972BackInBlackC10's Avatar
engine clearance issue
i just installed my motor and trans into my 67 chev and theres almost no clearance inbetween the valve covers and the firewall, im worried that under torque the motor will move and the valve covers will hit the firewall
theres pics below you can fit maybe a quarter inbetween them thats how much room there is, will i need to move my motor ahead? how can i do this? im using the stock motor mounts in the stock location the trans is also bolted to the crossmember, i cant put smaller valve covers on as it needs the clearance for the rockers, i can get more or specific pictures if anyone needs them
1972BackInBlackC10 is offline   Reply With Quote
Old 09-22-2012, 04:03 PM   #2
Lee H
Lee H's Avatar
Re: engine clearance issue
Does the 67s have two sets of motor mount holes in the frame? Looks like you may have them in the rear holes.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 09-22-2012, 04:07 PM   #3
gearys 5600
gearys 5600's Avatar
Yep, need to move the mounts to the forward holes.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 09-22-2012, 04:15 PM   #4
john
member #16
john's Avatar
Your engine is mounted to 6 cyl towers. You need 8 cyl towers to mount in the front set of holes. They are different from each other, and will not interchange. the regular chevy short valve covers will fit in the 6 cyl position.
john is offline   Reply With Quote
Old 09-22-2012, 05:18 PM   #5
gearys 5600
Those are the tall valve covers..
These frame stands looks to be the right ones, they just need moved to the forward holes.
I could be wrong but I think the 6cyl stands are the same as v-8 with the exception of the 292. The 230 and 250 I-6 I believe are the same.
Correct me if I am wrong.
1956 chevy nomad
Old 09-22-2012, 04:12 PM   #6
terry b
terry b's Avatar
That moter is way to far back. Hell it dont even cover the crosmember. You need to move the mounts up to the front set of holes in the frame.
terry b is offline   Reply With Quote
Old 09-22-2012, 05:21 PM   #7
jjzepplin
jjzepplin's Avatar
How do you tell the difference between the 6-8 cyl mounts? I just bought some and hope they are not 6 cyl? Anyone got pics?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-22-2012, 05:31 PM   #8
john
member #16
john's Avatar
The 6 cyl stands will not fit in the front set of holes and the 8cyl won't fit the rear set.
Old 09-22-2012, 05:36 PM   #9
sharpmark
makes sense cause if you lookat the original pics , if you just slide those mounts forward there is no bottom hole in the crossmember.
1969 stepside-305/4spd/12 bolt posi
http://67-72chevytrucks.com/vboard/s...d.php?t=477157
1968 pontiac lemans convertible-350/pwrglde/10 bolt
1934 oldsmobile sedan-350/350/12 bolt posi
1930 model a pickup-350/350/jag ind
1928 model a roadster-283/350/9"
sharpmark is offline   Reply With Quote
Old 09-22-2012, 09:25 PM   #10
1972BackInBlackC10
so apparently this was a 6 cyl truck, if i move my motor ahead my drive shaft will be too short wont it? if i move my mount one hole ahead there isnt a hole for the bottom, if i get a pair from a v8 truck will they work?
Old 09-22-2012, 09:47 PM   #11
sharpmark
unfortunately yes the driveshaft will be short,plus gearbox crossmember mounts will be further forward.
is it a floor shifter-cause that will move forward
clutch pivot shaft-ditto
good fun working on these old trucks-aye
Old 09-22-2012, 05:29 PM   #12
sharpmark
i used the 250 i6 stands in the same place for my 305
but i had smaller valve covers and plenty of clearance and didn't want to have to change driveshaft length and gearbox crossmember mounts.
plus i plan to go back to i6 .
you may have distributor issues as well if you use anything other then a standard one.
Old 09-22-2012, 05:32 PM   #13
sharpmark
these are 6 cylinder mounts
Old 09-22-2012, 10:07 PM   #14
sharpmark
just went out and had alook under mine
4spd manual and the xmember is rivited in and would have been a bastard to move forward as its right where the chassis rails turn up steeply.
there are a series of holes futher back the chassis which is where i presume the auto x-member would be so you may be lucky there
i can't be any more help sorry.
Old 09-22-2012, 10:11 PM   #15
1972BackInBlackC10
thanks for looking, mine is bolted in since its an auto i will have to check and see if there are any more holes, my dad said to take a ballpeen hammer and smack the firewall in so i have clearance, his logic behind this is that im not keeping the motor in this truck because im building a shortbox so why spend money on a truck im not keeping he said lol i wasnt going there with him
Old 09-22-2012, 11:34 PM   #16
71tahoe
71tahoe's Avatar
Moroso tall valve covers and HEI ignition will fit in the I6 position. I can't even install Edelbrock Elite tall covers on past the rockers and firewall but the Moroso work great.
71tahoe is offline   Reply With Quote
Old 09-22-2012, 11:37 PM   #17
SS Tim
SS Tim's Avatar
This link has a loi of good motor mount and stand information. Post #18 by Tx Firefighter has some very helpful pictures.
http://67-72chevytrucks.com/vboard/showthread.php?t=437680&highlight=motor+mounts
As to knowing what your truck had for an engine is easy. Check the VIN.
CS is a I6 gas
CE is a V8 gas
SS Tim is offline   Reply With Quote
Old 09-22-2012, 11:48 PM   #18
white 67
my 67 was a 6 cylinder truck and i had the same issuse when i tryed to put on tall valve covers. I got v8 stands and there was already holes for the auto crosmember in the right spots.
white 67 is offline   Reply With Quote
Old 09-23-2012, 12:05 AM   #19
1972BackInBlackC10
tim wheres the vin located?
Old 09-23-2012, 12:17 AM   #20
SS Tim
SS Tim's Avatar
The VIN will be located on the SPID label (if you have one) inside the glove box door. It is also repeated on the door post data plate. The CS or CE prefix will start both the model number and VIN numbers. Your vehicle title or registration will have the numbers as well.
Old 09-23-2012, 12:09 AM   #21
HotRod C/10
HotRod C/10's Avatar
i6 towers
http://67-72chevytrucks.com/vboard/s...44&postcount=3
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 09-23-2012, 12:17 AM   #22
1972BackInBlackC10
yup i have the I6 stands in the back position, thanks tim for that thread tx firefighters post was exactly what i was trying to find out, now i need to buy some v8 stands and hopefully i wont have to drill holes for my auto crossmember and i guess i will have to buy a different driveshaft too
Old 09-23-2012, 12:18 AM   #23
1972BackInBlackC10
yea my spid is long gone i will have to use the plate on the door, is there anyway to tell what trans it came with as well?
Old 09-23-2012, 12:40 AM   #24
SS Tim
SS Tim's Avatar
Now it is detective time. Without a SPID or a build sheet all you can go on is what you have or it appears you had. Temper that with know option and power train combinations. Firewall holes are also helpful. Do you "know" if your truck is an original automatic truck. What is the steering column like?
Old 09-23-2012, 12:48 AM   #25
1972BackInBlackC10
im not too sure if its originally an automatic, it doesnt seem to have markings on the tab located on the frame from where the clutch hooks up too, and i looked for where the crossmember would be for an manual trans with the I6 and theres no evidence of grinding the rivets so im assuming the truck was an automtic
