Old 09-22-2012, 08:49 PM   #1
landy
Cleaning the krap out of the cowl
So there's some accumulation of small sticks, dirt, debris, etc. in the cowl area and also behind the kick panel vent doors. I thought maybe sticking a hose in there to try and wash out some of the debris. Maybe an air hose? Any other ideas?
Thanks!
landy is offline   Reply With Quote
Old 09-22-2012, 08:57 PM   #2
Southern Shaker
Re: Cleaning the krap out of the cowl
i used my hands and a needle air hose atatchment worked great
Southern Shaker is offline   Reply With Quote
Old 09-22-2012, 09:00 PM   #3
landy
Hands won't fit in between the bars on the cowl area, and I can't fit my hands very well into the kick panel vents. I suppose I could remove the vent doors for better access. I don't want to remove the cowl, though.
Old 09-22-2012, 09:02 PM   #4
Beetle
Beetle's Avatar
So I took the cowl off, got a shop vac n sucked it all out, try that.
Jason
TEAM C10 HOT ROD POWER TOUR
689 Short Step
68 Step
Trucks Sold: 70 GMC, 72 K5
Members met: Andy4639 GCncsuHD CSGAS zicc1835 hotrod farm truck Mingrao Bhelton brenthiggins
Beetle is offline   Reply With Quote
Old 09-22-2012, 09:04 PM   #5
da-burb
"Ochre Ogre"
da-burb's Avatar
the vent doors pop out easy, hands, vac, and air all work. those stainless trash guards that sit under the cowl will help keep the debris out in the future.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 09-22-2012, 09:04 PM   #6
Southern Shaker
i first tryed the shop vac an it worked ok but couldnt get good enough sucktion so i took it off and hands and air hose trust me i just opened my vent doors today i got leaves twigs...a pencil all sorts of thingamajigs in there
Old 09-22-2012, 09:18 PM   #7
AirSpeed
AirSpeed's Avatar
Run a water hose down each vent after you remove the cowl and get all that crap out of there! If you don't get it all it will rust. The water won't hurt it but wet leaves and dirt soaking in there will. I cleaned mine out with air and thought they were clean until I ran a bunch of water through them, tons more crap came out!
AirSpeed is offline   Reply With Quote
Old 09-22-2012, 10:25 PM   #8
Daddy Brim
Daddy Brim's Avatar
I'm in the process of cleaning mine out right now. I went as far to take the heater box out of the truck. Lots of stuff up in the fan and heater core also. With the vent doors and that all out. It is pretty easy to clean out. I will reinstall with fresh paint and new seals.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 09-22-2012, 10:41 PM   #9
Hubscrub
Cruzin
Hubscrub's Avatar
i taped a heater hose to my shop vac and stuck it down and around to get stuff out.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 09-22-2012, 11:17 PM   #10
desertnick69
desertnick69's Avatar
Ditto
desertnick69 is offline   Reply With Quote
Old 09-22-2012, 11:29 PM   #11
longorange68
I did that 3 years ago and found a pack of pall malls, and an old drivers license when I helped a friend pick up a truck in Arizona. Arizona trucks don't see much rain, wish I had that problem up here in Washington State...
1968 Chevrolet C-10, 2WD, Longbox, Vortec 350, 700R4, 3.73 gears
Good judgment comes from experience, and experience, well......that comes from bad judgment.
1968 Chevy C-10 "Longshot": Bought used from my Uncle George in 1994 and proceeding to beat the hell out of it for 4 years. Sold it. Bought it back, dumped an ungodly amount of money into it since then.
longorange68 is offline   Reply With Quote
Old 09-23-2012, 12:04 AM   #12
landy
Looks like they are at least two bolts on each side and several phillips-head screws to get the cowl off? Also need to remove the wiper arms and antennae?
Thanks!
Old 09-23-2012, 03:13 AM   #13
BruthaMan
US Army Veteran
BruthaMan's Avatar
A few pics of when I did mine a few months ago:
Went to Lowes, in the section where they have sheet metal, and picked up some sheet metal screen. Comes in a metal sheet (very thin, but much thicker than normal house/window screen). Had to cut out two sections, one for each side of the cowl. Painted black and (for now) used zip ties to hold in place.
I park under an oak tree (over my drive way) and it sheds a lot. Really helped keep the leaves, acorns and other debris out.
BruthaMan is offline   Reply With Quote
