09-23-2012, 09:07 AM | #1 |
200R4 kickdown cable attach?
How does the kickdown cable attach to the 200R4? Do you have to take the transmission apart to put in another brand?
09-23-2012, 12:13 PM | #2 |
Re: 200R4 kickdown cable attach?
It's attached at the base by one bolt. You pull it up and unhook it from a wire inside. Slip on the new one and put the bolt back in. The carb or TBI or whatever end it is attached by a plastic clip piece you have to squeeze to release it from the bracket and a small metal retainer that holds it to the throttle shaft. Adjustment of the TV cable is important or it will burn up.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
09-23-2012, 01:27 PM | #3 |
thanks okgmc4. I have a 454ci, elderborck carb, connected to the 200r4 and the tv cable is intact. I was thinking about another brand of cable, however now that you have explained it, I will stick with this system and do my best on adjustment.
09-24-2012, 08:49 PM | #4 |
No insult intended but it would seem that your not too knowledgeable about your tranmi$$ion. Before you even drive it or possible ruin your transmi$$ion, read this:
http://www.cpttransmission.com/tech_tvcable.htm Setting it by pressure gauge: http://www.tvmadeez.com/ |
09-24-2012, 09:00 PM | #5 | |
thanks,\ larry |
09-24-2012, 11:38 PM | #6 |
Are you sure you have a 200R4 and not a 700R4?
09-25-2012, 05:52 AM | #7 | |
