Hey guys Ive been gone a while but Im back on the train again. Ive been searching high and low for pics of trailing arm mounted bags on a 60-62 frame. Im planning on a 2" block but cant seem to find pics of rear bag mounted at about 60% of the length of the trailing arm on a stock 60-62 frame. Im more concerned with the upper bag mount and a good way to mount it. I was thinking of making a plate to bolt to the under side of the top lip of the frame to hold the top of the bag. Then a generic circle plate bolted to the arm for the lower (completley centered left to right) but Im not sure if this is a feasable mount setup or not. Pics would be great.
Regards, Mike. Posted via Mobile Device |
Re: 60-62 rear bag mounting
heres my 62
But Found Her 25yrs Later!
It looks like you have both sides plumbed to a single line.
One thing I read in these forums is don't plumb the two bags to the same line, but have a separate line to each bag. The reason was if both bags share the same line, and you're going around a corner, air will move from one bag to the other. The bag with the load will just push air through the line to the other bag and you'll have a terrible lean. Posted via Mobile Device
#4 | |
Who Me?
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Thats basically exactly what I have in mind. Do you run any lowering blocks? If so what size? and how low does the back go? oh and what bags are those? Thanks for the pics btw.
umm they are 2 inch blocks I do not remember what the bags are I will have to go take a look and for how low it will go I don't know I still have the torsion bars up front for now but if I put bags up front it should get very close to the ground but the drive shaft will hit the cab so it will need to be cut to go lower.
You think isweet so it goes pretty low. Any chance you got a pic with it aired out?
just check out my build thread there should be some pictures there http://67-72chevytrucks.com/vboard/s...=478965&page=5
similar setup im gonna relocate the shocks like Saleens i still have about 2.5 in in the notch Slam specialties RE7's bags no blocks
Nice. It's kinda hard to tell but are your bags mounted next to the larger frame bracket for the bed? Nice too see your that low without blocks. Any frame or trailing arm clearancing?
62 Bowtie I just noticed your local to me. I think you should drive up here and let me get a first hand look at your setup....
![]() Regards, Mike. Posted via Mobile Device |
i did trim some of the trailing arm and yes its right where the bed rail mounts im not useing the stock mounts anymore as i have raised the bed and i got no problem cruisin out to your place gonna start tear down soon installing porter DM
Sweet well Ill shoot you a PM with my number give me a call when you wanna head this way.
I'm also looking for rear bag mounting options for the 60-62.
I was planning on mounting the bags in place of the coils, but I'm thinking the x-frame may create a challenge compared to the 63-66 frame.
#15 |
bumb
#16 |
Still looking for more info. 62Bowtie didnt make it up my way so I could check out his setup and snap some pics.
Project Change of Plans: http://67-72chevytrucks.com/vboard/s...d.php?t=513135 '62 C10 SWB '03 Express Van 5.3l Dead (parting out and using motor) '99 Silverado 4.8l 5 speed 4wd |
#17 |
Bump
#18 |
Bump
#19 |
![]() Join Date: Oct 2006
I would like some info too
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
#20 |
Who Me?
Here is my bags mounted where the stock spring was.. I used the stock hole for the bottom, I think and drilled two new holes for the top. The air line is right where the frame rails come together. Its a little tough to get tools in there, but it works great.
![]() ![]() I run about 50# of air in the bags and the ride height is good and the ride is soft.. THis is my usual ride height. ![]() This is aired out. ![]() Hope that helps. If you have any questions let me know.
#21 | |
I'm wondering how to route it around or through the frame there. Posted via Mobile Device
#22 |
Who Me?
I don't think I have a pic of the lines. I used 90 degree push lock fittings and they are pointing towards the front. The air line goes thru the frame to the firewall area. There is a hole near the steering column where they come thru to the controls. The passenger side line comes across near the tranny cross member.
#23 |
Thanks for sharing your setup. I know theres got to be more guys laying frame or close to it with a 60-62. Post 'em up.
#24 |
Thanks for sharing your setup. I know there has to be more guys laying fame or close to it with a 60-62 frame. Post 'em up.
#25 |
Bump
