09-23-2012, 06:13 PM | #1 |
7.4 vortec sending unit + electronic gauge...?
I've got my truck to the point where it starts (not tuned at all and not ready for a road test at all) but I noticed that I'm not seeing any movement on my oil presure gauge.
The factory oil presure sending unit on engine (7.4L out of a K2500, carbed) has a single connector just like the factory 1979 cluster I have. I connectred them together when wiring the tach and such, but I don't seem to have any movement. I've done a pile of google searching for the past hour, but all I seem to find is mechanical gauge setups. Am I missing thinging vital, or are they just not compatible at all...??? |
09-23-2012, 06:22 PM | #2 |
Re: 7.4 vortec sending unit + electronic gauge...?
They are not compatible, You will need a '79 sending unit, Same goes for the temp sender.
09-24-2012, 12:43 AM | #3 | |
The temp sensor I was able to reuse from the EFI intake...looks identical to the older units, but I haven't had the truck running long enough to check to se if it works Posted via Mobile Device |
09-24-2012, 07:49 PM | #4 | |
On Gen IV BBC's I use the right front oil pressure port (arrow)....Does you Gen V have this? |
09-24-2012, 08:23 PM | #5 |
I did some googling this morning.
Here's what I found incase anyone else is stumbling on this in google-land: -Gen6 bbc (maybe even the vortec sbc..??) and LS series all use m16x1.5 thread. -Old school Gen1 (pre LT1 I believe) uses 1/8"x27 NPT -Autometer and a few other companies make a male M16 X 1/8 NPT female adaptor, #2268...how sad is it that I've remembered the part number(?) -Summit Racing makes an electronic oil presure sensor for $20 that is 1/8" NPT $29 in parts and $38 in shipping/estimated duty/tax and those goodies are now on order.... Posted via Mobile Device |
09-24-2012, 08:51 PM | #6 | |
The 96-02 Gen 1 SBC used pipe thread. I didnt know the 99-00 454's used metric straight thread?? I know the 01 & up 8.1L does. |
09-24-2012, 11:19 PM | #7 |
For those interested, here are the Summit part numbers:
Adapter part number is ATM-2268 Sending unit part number is SUM-G2872-1 $29.xx for both Posted via Mobile Device |
