Old 09-25-2012, 01:03 AM   #1
1970gm4x4
Thumbs up 67 K20 build 454+nv500
I have a 67 3/4 ton 2wd automatic long bed fleetside.
I have a 96 vortec 454 and a nv4500 from the 96 truck i plan to put in this 67 while doing a 3/4 ton 4x4 conversion. And changing it from being a automatic to a manual. The 454 should mount in there fine and i plan to incorporate the computer and the fuel injection. I have to figure out the nv4500 and 205 situation, though i currently plan to buy the Advanced Adapters nv4500 retrofit kit. I have almost all the OEM components gathered to do this, the manual steering column, clutch pedal assembly, floor pan (i have to cut mine out), disc brake 3/4ton brake setup, and the 4x4 350 fan shroud. I have done a 4x4 and manual conversion before but not the 454 or nv4500. If you've done this, please feel free to give me advice. I'll put up pictures sometime.
1970gm4x4 is offline   Reply With Quote
Old 09-27-2012, 01:42 AM   #2
1970gm4x4
Re: 67 K20 build 454+nv500
The 67 gmc
The stripped frame
