Old 09-25-2012, 10:45 AM   #1
DevilDog Aggie
DevilDog Aggie's Avatar
Question from a non wrench turner
Ok, guys, question. I have always but some sort of gasket and seal on surfaces between components. Whether it is carb, valve covers, water pump etc. What about between the exhaust manifold and the block? Searched and have seen both yes and no. On both questions, gaskets and sealer. The exhaust manifolds are new Dormans. Obviously the block is original. I know there have been statements regarding having all ground flat/smooth. That really isn't an option at this point. So what should I do? Use the copper sealant and gaskets? Sealant and no gaskets? No sealant and gaskets?
Thanks guys!!!
Rob
'72 Chevy C-10 - 350-5.7/TH350/PS/PB/AC
Build Thread - http://67-72chevytrucks.com/vboard/s...87#post5503187
Semper Fi and Gig'em Aggies!
DevilDog Aggie is offline   Reply With Quote
Old 09-25-2012, 10:57 AM   #2
dmw319
Re: Question from a non wrench turner
Are you talking about header gaskets? If so I've always only used only gaskets and no sealant.
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 09-25-2012, 11:03 AM   #3
DevilDog Aggie
Between the exhaust manifold and the head. Seen many say one way or the other and trying to find a consensus. If one can be found! :-)
Rob
Old 09-25-2012, 11:06 AM   #4
dmw319
yep, header gaskets. I've always only used the gasket. Others here may have other views though!
Old 09-25-2012, 11:09 AM   #5
Lee H
Lee H's Avatar
As you have seen, a consensus can not be found. Here's my opinion, with fresh surfaces on both the heads and manifold, no gasket no sealer. With questionable surfaces on the head, manifold, or both I would use a gasket, no sealer.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 09-25-2012, 12:01 PM   #6
LMREESE
I would go with gaskets and no sealer. I've never even heard of not using gaskets.
67 C10 swb bored out 350 granny 4 speed
I come from a long line of moonshiners
LMREESE is offline   Reply With Quote
Old 09-25-2012, 12:04 PM   #7
dmw319
likewise.. even from the factory
Old 09-25-2012, 03:42 PM   #8
Fitz
My Sanderson headers go on without a gasket, and after almost 15K miles no leaks either.
Fitz is offline   Reply With Quote
Old 09-25-2012, 02:45 PM   #9
DevilDog Aggie
Thanks guys! I'll go with just the gaskets and no sealant.
Rob
Old 09-25-2012, 03:47 PM   #10
kcsa75
kcsa75's Avatar
As long as the surface of the block and the manifold are clear, no gasket. They didn't have them from the factory. If you do put a gasket in there, it's likely to just burn up and create leaks.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 09-28-2012, 11:48 PM   #11
Hubscrub
Cruzin
Hubscrub's Avatar
On manifold to head i never use gaskets no problems, only problems i've had are ones that somebody before me installed gaskets on burnt out and leaked.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 09-25-2012, 04:00 PM   #12
67ChevyRedneck
67ChevyRedneck's Avatar
Interesting... NEVER heard of not using a gasket until now...
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 09-25-2012, 06:14 PM   #13
LMREESE
I've been inside quiet a few motors and never found one without gaskets. My grandpaw who is a retired mechanic (in business 1945-1998) said he never saw one without gaskets either.
Old 09-25-2012, 06:21 PM   #14
Lee H
Lee H's Avatar
Willie is correct, none from the factory.
Old 09-25-2012, 08:35 PM   #15
WIDESIDE72
WIDESIDE72's Avatar
My 71 El Camino 350 originally didn't have gaskets. Same for moms 83 olds 88 307. No leaks! Those were the only unmolested engines I ever saw. I believe most gaskets you see were installed later on.
WIDESIDE72 is offline   Reply With Quote
Old 09-25-2012, 06:23 PM   #16
Kurt L
Kurt L's Avatar
on the older engines i've never used gaskets because i've found that most of them are flush mounts.[no gaskets] but on headers yes use gaskets. use to use two before they came out with the new self sealing gaskets for headers. never had a problem with them worked great.
Kurt L is offline   Reply With Quote
Old 09-25-2012, 07:19 PM   #17
big mike71
big mike71's Avatar
No gaskets, That just goes to show you're never too old to learn something new.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 09-25-2012, 09:41 PM   #18
slinginrods
slinginrods's Avatar
chevrolet factory tech here.later model stuff(90s up regular sbc)no gaskets.earlier stuff had gaskets.if the head surface is machined,which the later heads are(vortec style most crate motors from chevy)your ok no gaskets.the earlier heads were not so well machined so the factory used gaskets.most sanderson manifolds do not recomend gaskets.depends on the surface quality of the manifold and heads.
slinginrods is offline   Reply With Quote
Old 09-25-2012, 10:36 PM   #19
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
My Dougs headers installation instructions said to use their gasket along with a light film of Permatex Ultra Copper High Temperature Sealant.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 09-28-2012, 09:36 AM   #20
DevilDog Aggie
Thanks for all the info guys! I got them installed last night. Decided to go without gaskets and see what the results are. Both surfaces are clean and straight so I think it should be ok. Let her run for about 30 minutes last night and didn't notice/find any leaks.
Thanks again for everyone's advice!!!
Rob
Old 09-28-2012, 09:57 AM   #21
Lee H
Lee H's Avatar
Great, you will need to re-torque after a few heat cycles.
Old 09-28-2012, 12:41 PM   #22
DevilDog Aggie
Thanks Lee! Thought I probably would have to do that with the expansion/contraction.
Rob
