gas pedal adjustment
hi I just finished an engine swap and i noticed that my gas pedal doesnt have enough movement to floor my new carb. is there an easy adjustment?
1985 Chevy C10 swb 350 ![]() |
Re: gas pedal adjustment
Zip ties?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Can you adjust the throttle cable by the bracket with the square hole on the engine? Either on the intake or bolted to the back of the carb.
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
The cable has enough room to open the throttle like the bracket is far enough back it's just the pedal that is to close to the floor there's not enough room to pull the cable tight
Not sure what your running for a carb, linkage or cable but seems like you just need to take up some slack on the cable.
What you basically have to do is leave the cable attached to the carb then unbolt the bracket and pull the bracket back till the slack is out of the cable then somehow attch the bracket there . I purchased an AED aluminum throttle bracket for mine and that solved all my problems . Was 80 bucks but money well as easy adjustment for any carb i install now .
![]() 1985 C10 2004 Avalanche |
To raise up the pedal take a butt wire connector and remove the plastic shell....... Open up the aluminum and slide it over the cable by the pedal ....slide it towards the pedal raising the pedal and crimp it
Tags |
carb issues, gas, gas pedal, pedal, throttle |
