Old 09-28-2012, 02:11 PM   #1
slammeds1002
67/72 c10 half 2wd
i trying to figure out how to convert my 67 c10 2wd to disc from front drum. i would like to stay 6lug. what year from what and or what application year make model. can anyone help me please.
TRYING TO FIND WHAT MOTOR I HAVE BLOCK NUMBER RIGHT FRONT HEAD IS TO409S.
I CANT FIND IT TOLD 327 OUT OF IMPALA. ALSO TRYING TO CONVERT FROM MANUAL STEERING TO POWER.
NEED TO KNOW WHAT I HAVE PLEASE HELP
slammeds1002 is offline   Reply With Quote
Old 09-28-2012, 02:47 PM   #2
GMCJOE
GMCJOE's Avatar
Re: 67/72 c10 half 2wd
Here is a thread with a lot of disc brake conversion info.
http://67-72chevytrucks.com/vboard/s...68&postcount=4
I have a 69 I will be converting over to disc brake. I am keeping mine 6 lug, but everything is going to be new on the front end. Purchasing my stuff from CCP. The only used equipment I will have will be the power brake booster, master cylinder, proportioning valve, and brake pedal assembly.
If I didn't like the wheels I have so much, I would just do the 5 lug conversion from a 71 or 72. Much cheaper when you find a donor to get all the parts from. Good luck.
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 09-28-2012, 03:25 PM   #3
slammeds1002
Thank u so much
Old 09-28-2012, 03:38 PM   #4
doubleb's69
doubleb's69's Avatar
"S" is the suffix code for a 1962 327 mated to a powerglide for a full size car.
Bud
doubleb's69 is offline   Reply With Quote
Old 09-28-2012, 03:47 PM   #5
slammeds1002
So just bought this truck with that motor and manual steering to how would i put power steering in this truck finding brackets pump and gear any idea and thank u
Old 09-28-2012, 04:00 PM   #6
doubleb's69
Look in the 67-72 classifieds on this forum for the power steering stuff. The other thing is I don't know if the bosses on the drivers side front of the block are drilled and tapped on something that old but maybe. The reason that matters is that that is where part of the pump bracket bolts up to. So you will need that pump, brackets, steering gear, and crank pulley.
Bud
Old 09-28-2012, 03:57 PM   #7
GMCJOE
GMCJOE's Avatar
I suggest going to a salvage yard and finding a truck with the steering gear box still on it (that is if you don't want to buy new). Since you are wanting to change over to disc brakes, you might find a donor also. Far as I know, you can order a new steering gear box (power steering ready) from your local parts store and bolt it on. Mine was upgraded to power steering and still has the factory steering column. So that should bolt right up too. Don't take my word on it, search the forum. As for the brackets, find them on here or got to the salvage yard and find those too. Be surprised what you find at them.
Found a complete 71 chevy at one that someone drove in. Unmolested at that, very little rust. Wish I would have had the $1000 they was asking... Was a broke high schooler then.
Joseph
Joe's 69 GMC
Old 09-28-2012, 04:03 PM   #8
slammeds1002
Ok thank u so what you are telling me 72 c10 is all I need for all my parts
Old 09-28-2012, 04:06 PM   #9
doubleb's69
Here is a link for the steering parts. $50 for the pump and brackets and $50 for the steering gear.
http://67-72chevytrucks.com/vboard/s...d.php?t=544916
You could just buy a 71 or 72 parts truck to get all of the 5 lug stuff plus your power steering stuff if it is equipped if that is what you are asking from your post above.
Bud
Old 09-28-2012, 04:08 PM   #10
slammeds1002
I guess it's good I work in parts store
Old 09-28-2012, 04:17 PM   #11
slammeds1002
One more ? When convert to power steering do I need to change pitman arm and any other steering linkage
Old 09-28-2012, 04:19 PM   #12
slammeds1002
New pump is 39 dollars and new box 119.72 think better go new for the price
Old 09-28-2012, 06:05 PM   #13
cdowns
cdowns's Avatar
i'd just look for a really rust to crap 71 or 72 C10 that has power steering// that way you can get all the parts needed for disc brakes and power steering inin one deal
Old 09-29-2012, 11:10 AM   #14
slammeds1002
So im trying to change from manual steering to power but there no holes in head for brackets any ideas if any
Old 09-29-2012, 11:42 AM   #15
GMCJOE
GMCJOE's Avatar
The power steering pump brackets do not mount to the head. Mounts to the block. Depending on the brackets, there is a support bracket that mounts from the back of the pump to the motor mount. I will try to locate a few pictures for you.
Joseph
Joe's 69 GMC
Old 09-29-2012, 11:54 AM   #16
slammeds1002
that would be sweet i was really stressing out. i dont thank u for all your help
Old 09-29-2012, 12:02 PM   #17
GMCJOE
GMCJOE's Avatar
This thread might help you out. Show's a factory one and a after market one. If you are have problems finding one that works, I suggest just buying the Alan Grove one or the summit racing one he has the link to. The factory one he is showing has the ear missing for the top bolt. The Alan Grove and Summit Racing one both run pretty much the same price.
http://67-72chevytrucks.com/vboard/s...d.php?t=365766
Joseph
Joe's 69 GMC
Old 09-29-2012, 01:08 PM   #18
slammeds1002
Ok that tread helped out alot
Old 09-29-2012, 02:08 PM   #19
slammeds1002
With power steering brackets how do i relocate altenator the pic show th alt bracket but dont have those bolt holes on head
Old 09-29-2012, 02:15 PM   #20
GMCJOE
GMCJOE's Avatar
Can you show us a picture of the front of your motor... Pics help a lot. You will most likely have to go with a low mount alternator bracket.
Joseph
Joe's 69 GMC
Old 09-29-2012, 02:26 PM   #21
slammeds1002
Have to take picture when get home and post it at work. Not sure how work power steering being low on motor as well. This is all new to me and everyone thats helping me and the advise u all rock! Send pic later tonight
Old 09-29-2012, 04:02 PM   #22
GMCJOE
GMCJOE's Avatar
You can relocate the alternator to the passenger side of the motor with a low mount alternator kit. So, you can have the alternator on one side and the power steering on the other side.
Joseph
Joe's 69 GMC
Old 09-29-2012, 04:18 PM   #23
slammeds1002
Will that matter in the way the alternator spins for charging
Old 09-29-2012, 04:23 PM   #24
GMCJOE
GMCJOE's Avatar
Spins same way no matter what side it is on. Crank turns clockwise and so does everything else.
Joseph
Joe's 69 GMC
Old 09-29-2012, 04:25 PM   #25
slammeds1002
Ok cool. All new to me work on cars all the time just never like this. Kinda feel dumb thank you.
