Old 09-28-2012, 03:11 PM   #1
truckster
truckster's Avatar
Front Drive Shaft Slip Yoke
The search feature doesn't seem to be working at the moment. I'm wondering if the slip yoke on the front drive shaft is supposed to come all the way off. I only get about 1/2 inch of movement out of mine.
Thanks.
truckster is offline   Reply With Quote
Old 09-28-2012, 04:51 PM   #2
71K20chevy
71K20chevy's Avatar
Re: Front Drive Shaft Slip Yoke
Bump
I'm wondering too because mine does the same thing..
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 09-28-2012, 07:42 PM   #3
Jayschevy
Mine came all the way out on my longbed truck. I'm not sure on the shortbeds though.
Jayschevy is offline   Reply With Quote
Old 09-29-2012, 07:42 PM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
On trailing arm trucks the slip doesn't move much, so dirt and rust can make the slip hard to move outside its normal range of movement.
As long as where it slides freely it doesn't have any lateral play (torsional play is ok) you should be ok.
Are you chasing a vibration, changing ujoints, just inspecting?
Mark everything if you start taking it apart. The yokes are timed and the shaft is ballanced as an assembly from the factory. Any deviation and you will have a vibration that will tear carrier bearings up quick.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
