09-29-2012, 12:52 PM | #1 |
5.3 swap check engine light on
This morning I started my 72 that I recently installed a 5.3. The truck only has the cab installed on chassis. The motor has been running great. This morning it did not want to run so I added some gas. Now the check engine light is on it seems to be running fine. So I plugged my scanner in which I have never done to this truck. The scanner will not come on. The plug on the truck the pink wire is hot. I have disconnected my battery the light is still on. Does anyone have any ideas what to check to make my scanner work. I know the scanner works I checked it on another vehicle.
09-29-2012, 05:37 PM | #2 |
Re: 5.3 swap check engine light on
there should be 4 wires that are needed on the back of the obd2 port....2 should be black, and they go to ground, then there should be a purple wire, that is your serial data (communicates with your scanner), then the other should be orange, or pink, that wire is + 12volts, when the key is on (somtimes its always +12v tho)
Twin Turbo 64 nova project http://67-72chevytrucks.com/vboard/s...d.php?t=669163 68 camaro LS2/T56 vs. 06 GTO build http://67-72chevytrucks.com/vboard/s...d.php?t=516310 project incredible hulk build http://67-72chevytrucks.com/vboard/s...d.php?t=269754 project big red build http://67-72chevytrucks.com/vboard/s...d.php?t=342165 project "blue ray" build http://67-72chevytrucks.com/vboard/s...d.php?t=405465 |
09-29-2012, 05:45 PM | #3 |
68 short step. I left the battery disconnected for about 30 minutes and the truck was running good and the light was off. My scanner will still not work I have the pink wire hot I checked the two ground wires and my other wire is green not purple do you have any other ideas.
09-29-2012, 05:57 PM | #4 |
68 short step my motor and computer is a 03. I checked the pink (hot) pin and the ground pins how do I check the pin going to the computer.
09-30-2012, 03:08 AM | #5 |
Do you have power at pin 16?
09-30-2012, 09:22 AM | #6 |
Yes I have power at this pink pin
09-29-2012, 05:38 PM | #7 |
you will need to check pin #s 2,4,5, and 16, for your setup, id bet...(you never did say the year of engine)
10-02-2012, 05:42 PM | #8 |
if your scanner isnt coming on, then there is a problem with either the power or grounds, either the OBD2 port, or the scanner itself....how you check the serial data wire is doing a continuity test on it....
10-02-2012, 07:52 PM | #9 |
Thank you 68 short step I have power to the Obd plug and I checked the grounds so I was wondering if the new plug was bad. Where do you buy the new obd2 plugs.
10-02-2012, 08:00 PM | #10 |
10-02-2012, 08:04 PM | #11 |
what kind of scanner are you using ? have you tried a different scanner
10-06-2012, 02:01 PM | #12 |
I think I found my problem my hot wire (pink) is in the #15 plug not the #16. How do I remove the pin without damage.
10-06-2012, 07:20 PM | #13 |
It is fixed thank you for the help
11-04-2016, 02:27 AM | #14 |
