70Custom10
Lets see your Creative Plumbing and under hood accessory management...
I see a lot of people doing some pretty nice wire management. How about all mater of pipe/hoses/lines etc... including radiator hoses, heater hoses, brake lines, ac lines, fuel lines, hydro boost/power steering, air lines, vacuum lines or whatever plumbing you might have. Post up a pic with a little description. Maybe how you got to that point, why you modified your plumbing and how its worked out for you so far. Would you do anything different? I dont have any good pics to post up yet. When Im done with my truck (someday
![]() Ready... Set... GO! |
70Custom10
Re: Lets see your Creative Plumbing and under hood accessory management...
No takers huh?
dazed and confused
Big al has a nice setup. If you do a search with his name I think his build will pop up
members met: redbaron69, billsbowtie,nc67 |
Old member
Don't know if this is what your looking for but...I cut a length of aluminum conduit and made a top radiator hose.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
70Custom10
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Andy did you get your shifter wiring sorted out?
BBforlife there is a thread saying show me your engines that will give you a lot of ideas. I'll link it if I can find it. Here is one-------http://67-72chevytrucks.com/vboard/showthread.php?t=378111
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. Last edited by VetteVet; 09-30-2012 at 01:20 PM. |
Old member
blazerboy_4life,
The conduit fit the regular rubber hose inside diameter perfectly. So all I did was cut enough off the old hose to secure it. VetteVet, Yes, waiting on a micro switch for it. Well I think I have it figured out any way. ![]() ![]()
Tags |
hoses, lines, pipes, plumbing, vacuum |
